Hi Barb,
Thanks for your reply.
Is there another way than a phone number to access customer support (like an email address for example) because there is no phone number for New Caledonia and the phone number for Australia is only for domestic use so I can't call it.
Regards.
Christophe
Hi Christophe10,
We do understand your part, if you cant use a phone as of the moment you can chat with one of the Microsoft Surface Support. In that way, they can assist you fully on your concern.
You can check on this link : https://support.microsoft.com/en-us/products/surface-devices
Click on the "Try the virtual agent" in that way, you will be routed to a live agent.
Please keep us posted, if this helps you and for you Surface device case.
Edd
