After the last update, my Surface Pro has stopped charging and has been draining over time. Now it needs to stay connected to a power adapter or else it will get immediately shut off. The light is a stable white, and I have already uninstalled and reinstalled the battery driver with no change. This is a really serious problem because I have a lot of sensitive work files on here and I can't use them if my surface pro immediately shuts off when not connected to power.
I checked and saw many people are having the same issue as of right now. I really hope this is not related to last update, or if this is some planned obsolescence strategy. I really do like Microsoft products and have owned this SP4 for 2 and a half years now.
COMPUTER NAME | PHILLSURFACE |
SYSTEM PRODUCT NAME | Microsoft Corporation Surface Pro 4 |
BIOS | 109.3681.768 03.01.2021 |
OS BUILD | 19041.1.amd64fre.vb_release.191206-1406 |
PLATFORM ROLE | Slate |
CONNECTED STANDBY | Supported |
REPORT TIME | 2021-06-1108:10:10 |
Installed batteries
Information about each currently installed battery
BATTERY 1 | |
NAME | X910528 |
MANUFACTURER | DYN |
SERIAL NUMBER | 40261 |
CHEMISTRY | LION |
DESIGN CAPACITY | 38,152 mWh |
FULL CHARGE CAPACITY | 27,690 mWh |
CYCLE COUNT | 500 |
Recent usage
Power states over the last 3 days
START TIME | STATE | SOURCE | CAPACITY REMAINING | |
2021-06-0808:55:00 | Active | AC | 106 % | 32,295 mWh |
17:50:00 | Active | Battery | 106 % | 32,347 mWh |
17:50:05 | Connected standby | Battery | 106 % | 32,347 mWh |
17:50:22 | Active | Battery | 106 % | 32,347 mWh |
17:50:43 | Connected standby | Battery | 106 % | 32,347 mWh |
17:50:43 | Active | Battery | 106 % | 32,347 mWh |
17:52:29 | Connected standby | Battery | 106 % | 32,347 mWh |
17:58:45 | Active | Battery | 106 % | 32,347 mWh |
18:35:51 | Connected standby | Battery | 88 % | 27,007 mWh |
19:41:47 | Active | Battery | 87 % | 26,692 mWh |
21:21:04 | Active | AC | 22 % | 6,615 mWh |
2021-06-0900:10:15 | Connected standby | AC | 104 % | 31,830 mWh |
03:48:57 | Active | AC | 104 % | 31,830 mWh |
03:49:29 | Connected standby | AC | 104 % | 31,830 mWh |
08:57:35 | Active | AC | 105 % | 31,912 mWh |
08:58:10 | Connected standby | AC | 105 % | 31,912 mWh |
16:22:43 | Active | AC | 104 % | 31,830 mWh |
16:23:25 | Connected standby | AC | 104 % | 31,830 mWh |
2021-06-1009:41:47 | Suspended | 104 % | 31,710 mWh | |
09:42:50 | Active | AC | 100 % | 31,710 mWh |
09:46:34 | Connected standby | AC | 101 % | 31,942 mWh |
10:57:10 | Active | AC | 101 % | 31,942 mWh |
10:57:44 | Connected standby | AC | 101 % | 31,942 mWh |
11:03:14 | Active | AC | 101 % | 31,942 mWh |
11:30:00 | Connected standby | AC | 101 % | 31,942 mWh |
11:30:03 | Connected standby | Battery | 101 % | 31,942 mWh |
11:30:03 | Active | Battery | 101 % | 31,942 mWh |
11:30:43 | Connected standby | Battery | 100 % | 31,605 mWh |
11:32:26 | Active | Battery | 100 % | 31,605 mWh |
2021-06-1108:10:07 | Report generated | Battery | 47 % | 15,007 mWh |
Battery usage
Battery drains over the last 3 days
START TIME | STATE | DURATION | ENERGY DRAINED | |
2021-06-0817:50:00 | Active | 0:00:05 | - | - |
17:50:05 | Connected standby | 0:00:16 | - | - |
17:50:22 | Active | 0:00:21 | - | - |
17:50:43 | Connected standby | 0:00:00 | - | - |
17:50:43 | Active | 0:01:46 | - | - |
17:52:29 | Connected standby | 0:06:16 | - | - |
17:58:45 | Active | 0:37:05 | 17 % | 5,340 mWh |
18:35:51 | Connected standby | 1:05:56 | 1 % | 315 mWh |
19:41:47 | Active | 1:39:16 | 66 % | 20,077 mWh |
11:30:03 | Connected standby | 0:00:00 | - | - |
11:30:03 | Active | 0:00:39 | 1 % | 337 mWh |
11:30:43 | Connected standby | 0:01:43 | - | - |
11:32:26 | Active | 20:37:40 | 52 % | 16,598 mWh |
Usage history
History of system usage on AC and battery
BATTERY DURATION | AC DURATION | |||||
PERIOD | ACTIVE | CONNECTED STANDBY | ACTIVE | CONNECTED STANDBY |
2021-04-25 - 2021-05-02 | 1:29:17 | 3:00:43 | 78:02:13 | 48:26:08 | |
2021-05-02 - 2021-05-09 | 2:09:02 | 1:18:54 | 119:17:51 | 25:41:33 | |
2021-05-09 - 2021-05-16 | 1:43:11 | 0:12:44 | 128:21:41 | 33:15:52 | |
2021-05-16 - 2021-05-23 | 0:55:54 | 2:33:28 | 116:52:51 | 47:06:42 | |
2021-05-23 - 2021-05-30 | 1:32:59 | 0:11:00 | 67:33:25 | 90:26:38 | |
2021-05-30 | - | - | 13:37:03 | 10:22:37 | |
2021-05-31 | - | - | 14:43:33 | 9:16:06 | |
2021-06-01 | - | - | 12:25:54 | 11:33:42 | |
2021-06-02 | - | - | 15:29:09 | - | |
2021-06-03 | - | - | 1:41:28 | 22:18:04 | |
2021-06-04 | - | - | 10:27:03 | 13:32:32 | |
2021-06-05 | - | - | 16:16:00 | 7:43:25 | |
2021-06-06 | 3:49:29 | 0:51:30 | 7:35:27 | 11:42:59 | |
2021-06-07 | - | - | 15:56:58 | 8:02:34 | |
2021-06-08 | 2:18:31 | 1:12:26 | 13:10:04 | 7:18:29 | |
2021-06-09 | - | - | 0:12:04 | 23:47:41 | |
2021-06-10 | 1:12:37 | 0:01:43 | 0:31:01 | 10:57:51 |
Battery capacity history
Charge capacity history of the system's batteries
PERIOD | FULL CHARGE CAPACITY | DESIGN CAPACITY |
2021-03-14 - 2021-03-21 | 32,872 mWh | 38,152 mWh |
2021-03-21 - 2021-03-28 | 32,274 mWh | 38,152 mWh |
2021-03-28 - 2021-04-04 | 31,072 mWh | 38,152 mWh |
2021-04-04 - 2021-04-11 | 32,520 mWh | 38,152 mWh |
2021-04-11 - 2021-04-18 | 32,494 mWh | 38,152 mWh |
2021-04-18 - 2021-04-25 | 32,475 mWh | 38,152 mWh |
2021-04-25 - 2021-05-02 | 29,944 mWh | 38,152 mWh |
2021-05-02 - 2021-05-09 | 31,639 mWh | 38,152 mWh |
2021-05-09 - 2021-05-16 | 32,959 mWh | 38,152 mWh |
2021-05-16 - 2021-05-23 | 31,426 mWh | 38,152 mWh |
2021-05-23 - 2021-05-30 | 30,532 mWh | 38,152 mWh |
2021-05-31 | 30,532 mWh | 38,152 mWh |
2021-06-01 | 30,532 mWh | 38,152 mWh |
2021-06-02 | 30,532 mWh | 38,152 mWh |
2021-06-03 | 30,532 mWh | 38,152 mWh |
2021-06-04 | 30,532 mWh | 38,152 mWh |
2021-06-05 | 30,532 mWh | 38,152 mWh |
2021-06-06 | 30,532 mWh | 38,152 mWh |
2021-06-07 | 30,532 mWh | 38,152 mWh |
2021-06-08 | 30,532 mWh | 38,152 mWh |
2021-06-09 | 30,532 mWh | 38,152 mWh |
2021-06-10 | 30,811 mWh | 38,152 mW |
Battery life estimates
Battery life estimates based on observed drains
AT FULL CHARGE | AT DESIGN CAPACITY | ||||
2021-05-09 - 2021-05-16 | 2:37:10 | 21:11:45 75 % / 16 h | 3:01:56 | 24:32:07 65 % / 16 h | |
2021-05-16 - 2021-05-23 | 3:36:04 | 59:32:28 27 % / 16 h | 4:22:19 | 72:17:04 22 % / 16 h | |
2021-05-23 - 2021-05-30 | 3:08:20 | 20:08:06 79 % / 16 h | 3:55:20 | 25:09:36 64 % / 16 h | |
2021-05-30 | - | - | - | - | |
2021-05-31 | - | - | - | - | |
2021-06-01 | - | - | - | - | |
2021-06-02 | - | - | - | - | |
2021-06-03 | - | - | - | - | |
2021-06-04 | - | - | - | - | |
2021-06-05 | - | - | - | - | |
2021-06-06 | 5:12:33 | 27:56:19 57 % / 16 h | 6:30:33 | 34:54:41 46 % / 16 h | |
2021-06-07 | - | - | - | - | |
2021-06-08 | 2:46:23 | 117:00:44 14 % / 16 h | 3:27:55 | 146:12:56 11 % / 16 h | |
2021-06-09 | - | - | - | - | |
2021-06-10 | 2:12:06 | - | 2:43:35 | - |
Current estimate of battery life based on all observed drains since OS install
Since OS install | 3:34:25 | 79:50:17 20 % / 16 h | 4:17:59 | 96:03:27 17 % / 16 h |
