May 10, 2024
April 9, 2024
Click here to learn more 💡
Surface pro 3 Docking Station Power Cuts Out
Hello Dave Eckert
Thanks for reaching out to us. Sorry to hear you are having problems with the Surface Pro 3 and Dock.
- Can you explain the topology of the devices and accessories you have connected to Surface and the Dock?
- Does this experience vary based upon what is connected?
- Does this vary based upon the apps and features that are running?
- When did you first notice this?
- Please ensure that all updates are installed, restart Surface. Power cycle the Dock and check again.
Let us know what is happening.
Best regards
Hello Dave Eckert
Ok, let's start with the updates.
- Connect all accessories, as you would operate normally
- Manually check for and install all updates
- Restart Surface and check / install again. Do this until no further updates remain
- With everything still connected and powered up, unplug the power supply for the Dock. Wait for about a minute, then plug the power back in
- Restart Surface, manually check for and install any updates again. Restart and check again
Does your experience vary based on the accessories physically connected to Surface and the Dock?
Does running particular apps or using certain features seem to precede this happening?
Best regards
·Was this reply helpful?
Hello Dave Eckert
Sorry, I misunderstood when you said you were relying on automatic updates for your Surface, and that you power cycled the Dock with Surface undocked.
Without being able to determine what accessory (none) or app/function may be contributing to this behavior, this is going to be difficult to troubleshoot.
Does this happen even if Surface is not in use? Restart Surface, followed by a full shut down and start. With Surface idle and no activity from start, does this still happen?
Does the time to power down seem consistent when it happens? Does it regularly happen regardless of using Surface?
Best regards
Hi paul_787.
According to your description, we will suggest reaching out to our assisted support right away for further assistance.
Kind regards,
Clare
