Surface Pro 2017 - BSOD: KERNEL SECURITY CHECK FAILURE
I have a new Surface Pro 2017: i7/8GB/256. I was just chatting on Google Hangouts and all of a sudden I got a BSOD for Kernel Security Check Failure. This is a brand new device and I haven't really installed anything on it. Is anyone else having this problem?
The device is fully updated and I haven't played around with drivers or anything.
So far this just happened once.
open Event Viewer and copy and paste the details of this crash into a reply for
starters.
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          6/30/2017 6:44:24 PM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (70368744177664),(2)
User:          SYSTEM
Computer:      Name
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>5</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000400000000002</Keywords>
    <TimeCreated SystemTime="2017-07-01T01:44:24.935125100Z" />
    <EventRecordID>2135</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer>Name</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="BugcheckCode">313</Data>
    <Data Name="BugcheckParameter1">0x3</Data>
    <Data Name="BugcheckParameter2">0xffff9b8181af8780</Data>
    <Data Name="BugcheckParameter3">0xffff9b8181af86d8</Data>
    <Data Name="BugcheckParameter4">0x0</Data>
    <Data Name="SleepInProgress">0</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
    <Data Name="BootAppStatus">0</Data>
    <Data Name="Checkpoint">0</Data>
    <Data Name="ConnectedStandbyInProgress">false</Data>
    <Data Name="SystemSleepTransitionsToOn">5</Data>
    <Data Name="CsEntryScenarioInstanceId">11</Data>
    <Data Name="BugcheckInfoFromEFI">true</Data>
  </EventData>
</Event>
this COULD be hardware. since this is a new Surface Pro, I would return and
repurchase. Do NOT exchange online with Microsoft. If you are in the US, no
matter where you purchased it, a physical retail Microsoft Store should be able
to assist and swap you out for a NEW, UNOPENED Surface Pro.
>>Event ID:      41
>>Task Category: (63)
Thanks Barb! I went to Microsoft Store, and they did a fresh install with an USB stick of Windows 10. They said it's most likely due to the OS being corrupt. I haven't had BSOD since, but will update if that changes...
Last updated July 10, 2023 Views 1,516 Applies to:
