Surface Pro 2017 Backlight Bleed
Question: Why isn't Microsoft acknowledging the new Surface Pro 2017 display backlight bleed defect and ignoring its customers after the launch of the product? When will they solve the problem? Because all of the units have the defect and replacing it at the Microsoft store is not a viable solution at the moment.
My new Surface Pro 2017 core i7 8GB (lot 1722) has backlight bleed on the whole bottom edge and left side of the screen. You don't normally notice it in landscape mode because the black taskbar hides it, but if you read a white background fullscreen article in portrait mode it's pretty obvious with one side of the screen being brighter than the other side.This light bleed is most noticeable in the colours blue and white and harder to see in black colours (which are usually used in backlight bleed tests).
The quickest way to test and see if your screen has this problem is to press CTRL+ALT+DEL and bring up the blue screen. On the bottom of the blue screen you should see a bright blue/white bar compared to the rest of the screen which is the defective light bleed. All the showcase models in the Microsoft Store I looked at had this problem. I have yet to see a new Surface Pro without this defect. Can anyone post a picture of their CTRL+ALT+DEL screen without the light bleed?
I think people who claim not to have it aren't looking close enough to notice it. Is Microsoft going to acknowledge this display defect and are they working on fixing it in future batches?
Also, if I wait more than one month to exchange my Surface Pro would I get a refurbished model or a new one? If they are going to give me a refurbished model I might as well just return this defective device and get a full refund. When we pay premium prices we expect premium quality. This defect would have been acceptable on a cheap tablet, but not a Microsoft product. Please fix the issue as soon as possible!
Tip: If you want to test your screen on different colours go to http://www.deadpixelbuddy.com/ and choose a colour then switch to fullscreen (win key+shift+enter on Edge or F11 on Chrome) and view the fabulous results and take a picture and post it here so we can prove that it's a universal problem.
I AM NOT THE SOURCE OF THE PICTURES BELOW, THEY ARE FROM REPLIES TO THIS POST OR REDDIT LINKS GIVEN BELOW. THE FIRST PICTURE (WHICH HAS BEEN USED IN TECH NEWS WEBSITES) BELONGS TO WALMART MARKETING TEAM USER ON REDDIT! I HAVE ONLY GATHERED THEM HERE.
Subreddits discussing this topic:
https://www.reddit.com/r/Surface/search?q=backlight+bleed&sort=new&restrict_sr=on&t=month
https://www.reddit.com/r/Surface/comments/6nyb28/light_bleed_dark_spots_and_other_display_issues/?utm_content=title&utm_medium=hot&utm_source=reddit&utm_name=Surface
As you can see there are A LOT so do not deny the defect and claim it's a minor issue in a few models. TAKE RESPONSIBILITY MICROSOFT!
Edit: I just realized I posted the original issue as a discussion post and therefore it didn't have the requirement for it to be responded like a question, so I'm editing it so people can also click the "Me Too" button until we get an official/semi-official response from a Microsoft representative. I've also added more subreddits and pictures.
UPDATE (17/07/2017 11:25 AM GMT): The broken image links have been fixed.
ACKNOWLEDGEMENT: A lot of tech websites have reported the issue and especially used the first image in this post and attributed it to me. I must note that none of these images are mine and they all come from the reddit posts I linked below them. The specific top image is from the user WalmartMarketingTeam
https://www.reddit.com/r/Surface/comments/6k94qe/just_bought_my_new_surface_pro_2017_i_might_be/djk79ga/
http://imgur.com/vbofsSa
I have this problem too, and as far as I can tell, this defect is nearly universal. Every SP 2017 I have seen in person has this defect. This includes: (1) every SP2017 on display at the Microsoft store in Atlanta and (2) three SP2017s I have personally ordered and have returned. Here is an image of my third display: http://imgur.com/DMR2j5O
Folks on Reddit have shared similar experiences with ALL display models at the Microsoft stores at NYC and LA. I have read about probably hundreds of these devices having this issue. This is unacceptable, and it is borderline insulting that Microsoft thought it could charge people so much money for a defective device.
This is a problem that ruins the experience of using a SP2017. Every time I write in OneNote, I noticed it. When I type in Word, I noticed it. When I tried reading a book using Kindle for PC, I noticed it. It is infuriating, though, because otherwise this is such a good machine. But the screen defect is so bad I am going out of my way to warn people about it and encouraging folks to not spend their money on it or to return it within 30 days.
More threads where this is being discussed:
https://www.reddit.com/r/Surface/comments/6i8lcz/backlight_bleeding_surface_pro_2017_i5_8gb/
https://forums.windowscentral.com/microsoft-surface-pro-2017/461352-do-you-guys-have-any-backlight-bleeding.html
https://www.reddit.com/r/Surface/comments/6hhqlf/defective_screen_surface_pro_2017/
I want Microsoft to: (1) acknowledge the problem and (2) announce when this will be fixed.
86 people found this reply helpful
Picked up a i5 256gb 8gb today, same issue.   Lot 1719
I wasted an hour with three call and two chats with UK Surface support team who where not at all helpful  - said I could wait 8-10 days for a refurb but much better to return to retailer.
So that's what I did - very helpful UK retail chain, known for thier customer service very kindly checked repacement from lot 1724 with exactly the same problem.
For those who want to check before going through the set-up process hold Surface in portrait mode on Out Of Box screen and a white glow it is clearly visible on botttom edge (the keyboard connection side).
I checked two display models - both exhibit problem, as it's mainly the bottom of the screen it's less noticable with taskbar and non uniform background.
I also compared with older models in store display and the difference is noticable, the old models on display did not have the problem.
My current plan is to return again within 30 refund policy of retailer and get a replacement if they have one if not I'll get a refund and go back to my Macbook running Windows in a VM.
MY ADIVCE WAIT UNTIL THIS IS RESLOVED
IF YOU CAN'T WAIT DON'T BUY ONLINE, buy in main retailer and check screen in portrait mode before leaving the shop.
This is like the old days of TFT screens hunting for a unit without dead pixels.
Frankly if Microsoft wnat to emulate Apples pricing model and set a price levels on the value proposition rather than based on component cost to extract nearly £1500 for a pretty basic specification then they need to work on the QA and support.
A sensible vendor would quickly acknowledge the fault and make assurances to market that replacements would be available rather than risking having a hole range of tablets considered a lemon by savvy buyers.
Jeez, what a nightmare. This is unacceptable.
Same here, just bought this in Italy, a 3400+ euro top tier notebook (16 gig ram 1TB ssd i7) and the screen has this shameful performance. Big disappointment. I'll be returning it.
I've had the same experience, I'm on the 3rd replacement now and all have this defect, the bottom section of the screen is much brighter and it ruins the whole experience. I've had devices from LOT 1719, 1720 and 1725 and all are defective, so this points to a widespread issue.
For a device which is marketed and priced as a premium device , this is extremely disappointing.
I've got that light bleeding issue too on my surface pro 2017 (i5 256). That's not what you wanna see when you spend more than 1500$ on a product.
Here from Italy too. I'm on my third unit from Amazon 2 i5 8gb and now 1 i7 8gb: this last one is the most decent of the lot so I'm going to keep it for now.
But really, I have had among other tablets/computers 2 Surface Pro 3 and 2 Surface Book and this is the first time I see such a horrid display from Microsoft. They never really shined compared to others (banding on a white to black gradient has always been embarrassing) yet this time the screen luminosity is so uneven it feels like dealing with a couple hundred bucks Chinese Windows tablet instead of a premium device.
Interesting--you're not the first person to suggest that the i7 models might have less of a backlight bleed issue. I wonder if the design of the fanless models is to blame.
I returned two i5 units from lot 1722 and got an i7 lot 1723 and it us much less noticeable. Still there, just not as bad. I'm on the fence about returning it.
I wish it were true, i7 1TB ssd, 16 gb mem, lot 1721, look at the screen, it is outrageous:
Last updated May 3, 2024 Views 38,986 Applies to:
