Surface Laptop 3 USB-C Ports Specs
Does anyone know what the specs are on the USB-C port on the newer Surface Laptop 3? Is it a USB-C 3.1 or 3.0 port?
I cant seem to find the technical specs on it.
Aaron
Hi, AaronLafferty!
Thanks for reaching Microsoft Community. The Surface Laptop 3 has a USB Type-C 3.1 port.
We hope this helps you out, we highly encourage you to inform our Community by clicking on Yes or marking my post as an answer. This will help other members who may have the same issue as you. Otherwise, don't hesitate to update us so we can further assist you.
Kind regards,
Janette_Z
Hi, AaronLafferty!
Kind regards,
Janette_Z
Do you know if itnis a Gen 1 or Gen 2 port? Thank you for your quick response.
Hi there, AaronLafferty!
We are sorry for the late response. I will have to check further on the USB Type-C specs if it uses Gen 1 or Gen 2. I will update you as soon as we get word on this.
Thanks for your time!
Janette_Z
Thank you so much for your patience. I was able to check with our team and clarified the specs of the USB Type-C port on the Surface Laptop 3. I am sorry for the information I initially shared.
Please allow me to correct this. The USB Type-C port uses 3.2 and is Gen 2.
We hope to have answered your inquiry.
Sincerely,
Janette_Z
23 people found this reply helpful
Last updated April 11, 2025 Views 4,733 Applies to:
