Surface book 2 USB C Charging?
Greetings
Hope to find someone who got some info about how charging thru the USB C port works on the SB2. Since apparently my Power Inverter wont work.
Got access to a 12v and a 24v (alltho the 24v is some weird tinny one) But both say they can handle over 100W (think its 120 for 12v and 240 for 24v), should work there since the normal power brick says 102W.
So can i just get a Car Charger rated for as much W as i can get? does Quick Charge assist? Is there some special charger that's needed?
And to be honest, slow Charging isn't the issue. Most often i will be able to leave it charging for an easy 7-10 hours in the truck if it wants that, to then use it 1-4 hours so.
Any enlightment in this issue is appriciated, since so far ive mostly seen allot of... Maybe's
Many Thanks
-Rasmus
Hi RasmusÅkerholm ,
You can charge using the USB-C port on your Surface Book 2 but only when Surface Connect power source is not in use. The USB C port can provide output power, and draw power for charging. Although we always recommend using the Surface Connect charger that came with the device. We know there are times people may not have their charger with them and a USB-C charger can be used.
Regarding your question about using a car charger, we have a vehicle charger that is recommended on your Surface device. This charger can quickly power your Surface device and it inserts effortlessly into your car's accessory power outlet to make powering up easy. Currently, it is only available on Microsoft Store US.
I hope this helps but should you need further assistance, feel free to reply back.
74 people found this reply helpful
Last updated April 11, 2025 Views 67,611 Applies to:
