Surface Book 2 Energy options Allow wake timers
Hello everyone!
Does someone know, why on the surface book 2 the option "Allow wake timers" is missing in the "Power Options", "Advanced Settings" , "Sleep" section?
Or does someone know how to make this option visible?
On my surface book 2 I have tasks in the task scheduler (really simple tasks calling a local batch file, no network etc.) that are never executed at the scheduled time. These are executed a few hours later or when I manually wake up the PC.
As far as I know it is essential to enable the "allow wake timers" option to enable the task scheduler to wake up the PC from sleep mode.
Can someone confirm this?
Anyone managed to do this on the surface book 2?
Thanks for your help.
P.S. The same task scheduler setup works without problem on a Lenovo Notebook (where I have the "allow wake timer" enable option) and tasks do happen at the time when they are scheduled.
Hi Mrsaxobeat,
Thank you for posting us here in Microsoft Community!
"Allow wake timers" is not enabled by default on the Surface device because of the Modern Standby (previously Connected Standby). In Modern Standby, the PC uses the S0 low power idle model which has the flexibility to configure the default behavior to limit network activity while in the low power state. Windows 10 reduces power consumption by the OS and only wakes from the lowest power state when absolutely necessary. With Modern Standby, the system wakes when there is real time action required, such as OS maintenance, or a user wakes the system.
However, we will look into this further and check for an option for you to possibly enable it. For the meantime, please provide us with the operating system, Version and OS build of the Windows running on both your Surface Book 2 and Lenovo Notebook.
To check for the operating system information in Windows 10:
  1. Select the Start  button, then select Settings  > System > About.
  2. Under Device specifications, you can see if you're running a 32-bit or 64-bit version of Windows.
  3. Under Windows specifications, you can find out which edition and version of Windows your device is running.
For other Windows operating system, go to Which Windows operating system am I running?
Keep us posted so that we can assist you further.
ALL Surface Books (and other Surface devices) come with 64 bit Windows. Why
would yo even ask to check this?
If you want to try to test and see if Connected Standby is preventing this
feature from being available, there is a registry edit you can try AT YOUR OWN
RISK. Turn on System Restore and create a manual restore point before
experimenting so that you have a good known config to go back to.
 Open the registry editor (regedit.exe)
 Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power.
 Double-click CsEnabled and set to 0, then click OK
 Restart
Check and see if you can now set the wake timers. If not, go back and set
CsEnabled to 1 and restart again.
Thanks for your replies !
I originally posted this in the german microsoft surface forum, but only few people seem to read the posts there and there are usually no replies...
So thumbs up for the english/us forum 👍
I have checked the OS Versions and registry on both machines an they are exactly the same for the Surface Book 2 and the Lenovo ThinkPad T530:
Edition: Windows 10 Pro, 64-bit Version
Version: 1809
OS-Build: 17763.316
Registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\CSEnabled = 1
So it seems that Connected Standby is also enabled on the Lenovo and there I see the "Allow wake timers" option in the advanced energy settings.
I don't like the idea of doing registry tweaks because
a) Microsoft might not support me any more if I do that and
b) The tweaks are usually gone when you do a Windows update
It shouldn't be necessary to do Registry Tweaks to make the task scheduler function properly.
It is not necessary on other machines.
Has anyone managed to wake up the Surface Book 2 from sleep via a time scheduled task scheduler job at the scheduled time? Or am I the first one trying to do this?
Can someone maybe do the same test on his/her Surface Book 2 like I did:
Set up a task in the taskscheduler that executes a .bat script that prints date and time into a .txt file at 2:00 at every night? That would be great.
The .bat script does look like this:
date /T >> outfile.txt
time /T >> outfile.txt
This enables me to see when the task was actually executed.
Looking forward for your comments and suggestions.
Thanks !
Hello Barb,
Thanks for the suggestion.
I tried that one 2 weeks ago and did it again last night just to make sure I haven't made a mistake.
The tweak makes the "Allow wake timer" option visible in the advanced energy options but it does not lead to successful execution of the task scheduler task at the scheduled time. So unfortunately it does not help :-(
And also, the "Allow wake timer" option disappeared again when updated to the latest Windows build...
Any other ideas?
No other ideas. I don't know why this is not available on Surface devices, and
if the unofficial tweaks and kludges don't work, it has to be by design. It is
not just the Surface Book that does not have this setting. All I can suggest is
to use the Feedback Hub to file this as a problem report.
Thanks Barb,
I have given up on Microsoft support. Spent hours with the telephone support explaining the problem to a dozen of people (sometimes after explaining what the windiws task scheduler is), wrote emails to *** Email address is removed for privacy ***, used the Feedback Hub.
Worst support experience ever ! They just close support cases without giving you a chance for feedback.
It is like you want to get into the Microsoft castle and they are throwing rocks and boiling oil on you.
Seems they are not very interested to help their customers.
It would be a chance to prove that their products (which are not the chespest ones) do support their own OS Windows 10 as good as other far cheaper products on the market. But they don't want to.
So maybe this comment can help others to make the right decision when it comes to buying microsoft products or the ones of other manufacturers. For me the decision is made.
After many many calls with Microsoft support and many hours of phone waiting music I finally got in contact with a support person with in depth knowldege.
Answer:
The surface book 2 does (only) support the new "Modern Standby" Energy management. Wake-Up is only possible by pressing the ON-key or by an external server which pushes software updates.
Wake-Up by the Task scheduler (wake timer): Not possible
Wake-Up by Wake-On-LAN: Not possible
Wake-Up by something on the USB-Port: Not possibel
Wake-Up by disconnecting/connecting power: Not possible
Disable Modern Standby: Not possible
The only thing you can do to make sure that scheduled tasks are executed at the time they are scheduled is to leave the surface book on and disable all Energy saving modes.
Great! A 1200$ Microsoft-Windows-PC which das not support the functionality forseen by the Microsoft Windows Operating System.
Thank you Microsoft!
16 people found this reply helpful
Last updated April 5, 2021 Views 982 Applies to:
