Thanks for your response, Auss1e_Jo.
At this point, we would highly recommend that you reset the Surface using a USB Recovery Image. This option reimages the entire device, including the partition on the hard drive. It is the most complete form of reset. You must have at least 16GB/32GB of USB Flash drive and it must be formatted to FAT32 prior to downloading the Recovery Image.
Note: This removes all the files and apps on your device. You will need to back up your data and reinstall the desktop apps or run updates after the completion.
To download the Recovery Image:
Visit the page at http://www.surface.com/support/warranty-service-and-recovery/downloadablerecoveryimage
Sign in with your Microsoft Account (this is the email address we asked you for at the start of the call)
From the list of Surface devices available, select the device that you need a recovery image for
Please note that while you will only be presented with devices that are currently registered on your account, you will also be presented with the option to get an image for a different type of device. If you try to use this option, you will be prompted to enter the serial number for that device
Download the recovery image using the button on the page
When the download bar pops up at the bottom of your screen, save the file in a location you will be able to find it.
Format USB Drive:
Insert your USB drive into the USB port of your PC.
From the desktop, open File Explorer
Tap and hold or right-click on the USB drive and choose Format
Select FAT32 as the file system and enter a Volume label to name the USB drive, such as RECOVERY, and then tap or click Start
Tap or click OK to erase the contents of the USB drive
Tap or click OK when the format is complete
Create a recovery drive:
On your Surface or PC, open recovery image that you downloaded by double-clicking it
At the top of the window tap on Extract and then Extract all. Select the USB drive you formatted earlier for the location and click Extract.
Perform USB recovery image:
Turn the Surface off by pressing the power button
Insert the USB recovery drive into the USB port
Press and hold the volume-down (-) rocker
Press and release the power button
When the Surface logo appears, release the volume-down (-) rocker
When prompted, choose your language options and keyboard layout
Select Troubleshoot
Select Recover from a drive. If prompted for a recovery key, select Skip this drive at the bottom of the screen.
If prompted, select Repartition the drives.
After the completion, if issue persists, then it's more likely a hardware problem already. For further assistance, kindly contact our support via Contact Us Microsoft Support to seek exchange options for your device. You can also contact them via phone, see Global Support Phone Numbers. Replacement cost applies to out of warranty device and for further service.
