New Surface Pro 6 - Office 365 Business Premium - Login - Microsoft account not found
I bought a new Surface Pro 6. I tried logging in with my Microsoft credentials used for office 365 business premium. I am the Admin. Same login I use on MacBook pro. I get message Microsoft account not found. I then Call support line. the guy says I have to have a gmail or other type of Microsoft account in order to get into the surface. I asked why and he said if he told me he would be fired. I will be returning the surface pro 6 today to the Microsoft store. It appears they do not allow you to use your own domain for credentials.
Reply In reply to deleted message
Did that. 5 hours and no clear answer.
Austin Expert was a tech support scammer. Don't call that phone number.
I suggest you create a local login for your SP6. You can then sign in to your
O365 account and download office.
The answer to the problem is to make sure you buy a Commercial Surface Pro 6 and not a consumer model. I had to return mine. I found that out after I called the number and gave them my social security number. /s.
Well, yes and no. Consumer SP6 comes with Windows Home. You CAN purchase an
upgrade to Windows Pro -
- and then you can login/join a domain. if you aren't actually joining a domain,
you can log in with a local account or Microsoft (consumer) Account on a Windows
Home computer and still use O365 Business Premium with hosted email and you can
login to your O365 account and download and use the apps.
Last updated April 5, 2021 Views 250 Applies to:
