My Microsoft Surface 7 charger is making noises
My Microsoft Surface Pro 7 charger is making a hissing noise when charging. I am on Power mode which is the recommended setting while charging. The sound is coming from the actual box on the charger. It is not very loud but I can hear it if I listen closely or put it to my ear. Is this normal?
Hi, AlexStone_098!
Thanks for reaching Microsoft Community and posting your inquiry here. We're sorry to learn about your charger making sound from the actual power brick. Based on what you described, the charger should not make any audible sound while charging. Have you tried plugging it into a different wall outlet? If the same thing happens on several wall outlets, please have it replaced.
Kindly Contact Microsoft Support to get assisted by one of our advocates to process your charger replacement.
1.    Please make sure you are signed into your Microsoft Account when you go to that page above, then click Contact Support.
2.    A new window will pop-up showing the Microsoft Virtual Agent.
3.    Type Replace my charger then press Enter.
4.    In the responses, click None of the above until you get to another response that gives you an option to Talk to a person.
5.    Once you click Talk to a person, select Surface when asked for your product and hit Next.
6.    Select Warranty and service when asked for the issue and click Next.
7.    Still click on Next button when asked for a bit more info.
8.    You will be asked to register your Surface Pro 7 (if not yet registered) or choose it (if already registered).
9.    Kindly wait so that you will see an option for a callback.
10.  Enter your phone number and confirm it.
11.  You should see a confirmation that your scheduled callback has been successful and a call will be made within the expected timeframe.
If you prefer to call and outside the US, please check this page to know the number for your country in our list of Global Customer Service phone numbers.
If this answers your question, please let our Community know by marking this post as an answer. Otherwise, don't hesitate to respond to this thread if there’s anything else that needs to be addressed.
Kind regards,
Janette_Z
Last updated November 16, 2024 Views 3,313 Applies to:
