May 10, 2024
April 9, 2024
Click here to learn more 💡
Mold on Microsoft Surface Laptop 2
Hello SK228,
Thank you for reaching out Microsoft Community. Can you try to use swirling motions, gently clean with a white line-free cloth dampened with soap and
water. A simple solution of two parts water to one part mild soap (like hand soap) will do. Wipe dry using a clean light-colored cloth. Or see Clean
and care for your Surface.
KarenJune_F
Hi Karen,
Unfortunately no luck with the soap and water suggestion either. I have attached a picture in case that helps.
Hi Karen,
Hi SK228,
Thanks for your patience on this. We appreciate your effort in posting and also in cleaning it. As a suggestion, you might try to visit the store to have this check.
You can also contact our Microsoft Support at 1-800-642-7676 or Chat with us at http://www.microsoft.com/surface/en-us/support
If you are not in US, you can refer to Microsoft Support in your area on this link :
https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers
Please let us know if this helps. This will help other members who may have the same issue as you. Otherwise, don't hesitate to update us by posting or replying.
Edd
Last updated January 3, 2024 Views 500 Applies to:
