May 10, 2024
April 9, 2024
Click here to learn more 💡
Lost Surface Pen
Hi, briannabaxt!
Thanks for reaching out to Microsoft Community and posting your inquiry. We are sorry to learn that you're unable to locate your Surface Pen. Thanks for taking the time to let us know about this and allowing us to help you out.
Make sure you are signed into a Microsoft Account on the device and it has administrator access. Aside from being signed into your Microsoft Account, you will be able to utilize this function if the device has enough battery power so it can send its location.
Go to Settings > Update & Security > Find my device.
If it is off, I am afraid that the pen cannot be located.
If it is on, please go to this page to be guided on how to Find your Windows device.
We hope this helps you out.
Kind regards,
Janette_Z
·Was this reply helpful?
If it is on, please go to this page to be guided on how to *Find your Windows device*
Janette,
Find my pen depends on the location of the host computer. It may show (but most
often does not) the location that the Surface was used and the Pen was connected
but it will not pinpoint the location of the pen, say "under the sofa" or "3
feet from the TV". Good tutorial at
https://www.windowscentral.com/how-find-your-surface-pen-windows-10-fall-creators-update
Last updated May 16, 2024 Views 8,994 Applies to:
- Surface
- Accessories
- Accessories
- Pen
