Share via
Itunes movies on Surface Pro X
Anonymous
Jul 26, 2020, 10:12 PM
I'm trying to watching some purchased movies on the iTunes app. When I press play the movie pops up with the features options and play movie button. When I select play on the movie, the actual movie will not show but the audio plays.
I downloaded one of the movies to see if that would help and the neither the movie nor the audio will play. Please let me know how I can fix this issue.
Surface | Surface Pro | Display and screen
Locked Question. This question was migrated from the Microsoft Support Community. You can vote on whether it's helpful, but you can't add comments or replies or follow the question. To protect privacy, user profiles for migrated questions are anonymized.
0 comments No comments
{count} votes
Sort by: Most helpful
  1. Anonymous
    Jul 27, 2020, 2:47 AM
    Hi AustinBarnum,
    Thank you for reaching out to Microsoft Community.
    How about other video formats that is saved/downloaded on the device, does it have the same issue?
    Did you install iTunes app through the Microsoft Store app?
    If yes, please run these steps on your Surface Pro X then try to check again if issues persist:
    1: Run Surface Diagnostic Toolkit and check Windows Update
    2: Run System File Checker Tool in Windows 10
    3: Get updates on apps and games from the Microsoft Store
    If this answer your question, we highly encourage you to inform our Community by clicking on Yes or marking my post as an answer. This will help other members who may have the same issue as you. Otherwise, don't hesitate to update us so we can further assist you.
    Kind Regards,
    Marrion Y.
  2. Anonymous
    Jul 30, 2020, 9:34 PM
    Marrion,
    Unfortunately, none of that helped. The other videos work fine. The file for the iTunes movies I wanted to watch on my Surface X are .M4V and I wonder if that is the problem. Can these devices watch .M4V files?
