Inserting micro SD card in surface pro 7+
I'm having trouble inserting a micro SD card in my wifi surface pro 7+. I can locate the small slot just below the kickstand but the card does not slide smoothly in and I'm worried about damaging sharing. All the videos I see are for other models and the skit on my device is closer to the kickstand that the ones shown. Please advise/assist.
Hello Mark3080,
Thanks for reaching out to Microsoft Community. I'm sorry that you're having a problem inserting the microSD card into your device.
May I know which Surface Pro 7+ you have? Is it the Wi-Fi model or with the LTE advanced feature? Find out which Surface model you have - Microsoft Support
Take note that Surface Pro 7+ with LTE Advanced doesn't have a microSD card slot. If you have the Wi-Fi model, on the left side of the Surface near the hinge, you'll see one of the following:
  1. SIM tray
    The tray is inserted into the device and requires the SIM ejector tool to remove.
  2. microSD card slot
    An exposed slot where you can slide a microSD card and click it into place.
Can you confirm please if you have these slots by providing a photo here?
Looking forward to your response.
StevenK
Make sure the gold-plated area of your microSD card is facing down when you put it on the device. Push the microSD card with a little force until you hear a clicking sound.
Last updated April 11, 2025 Views 4,653 Applies to:
