Share via
Fix for pressure spot on screen
Anonymous
Jul 14, 2021, 11:37 AM
It appears that there are two new small pressure spots near the bottom of the screen that are only visible in darker backgrounds with a higher brightness. Cant seem to find many posts about the topic or any fixes about them. So far I've tried running the surface diagnostic tool and have updated the device to the latest firmware and they are still there. I've had this device for more than a year now so the warranty has expired. I can't go to a Microsoft store since I reside in Malaysia and any help would be appreciated.
Surface | Surface Pro | Display and screen
Locked Question. This question was migrated from the Microsoft Support Community. You can vote on whether it's helpful, but you can't add comments or replies or follow the question. To protect privacy, user profiles for migrated questions are anonymized.
0 comments No comments
{count} votes
1 answer
Sort by: Most helpful
  1. Anonymous
    Jul 14, 2021, 8:16 PM
    Thanks for posting your concern here, suchit_k. We're sorry to learn about this issue on your device.
    If I may ask, have you also noticed an interference to your mouse clicking, keyboard typing or touch inputs on your screen? If yes then try disabling the touch drivers on your device. Open Device Manager > Human Interface Devices > Expand Human Interface Devices, and Right-click HID-Compliant Touch Screen > then Disable. Once touch drivers are disabled, check if issue persists or not. If issue went away, then your device may be experiencing phantom touches.
    In this case, we suggest to reset the Surface using a USB Recovery Image. This option reimages the entire device, including the partition on the hard drive. It is the most complete form of reset.  You must have at least 16GB/32GB of USB Flash drive and it must be formatted to FAT32 prior to downloading the Recovery Image.
    Note: This removes all the files and apps on your device. You will need to back up your data and reinstall the desktop apps or run updates after the completion.
    To download the Recovery Image:
    1. Visit the page at http://www.surface.com/support/warranty-service-and-recovery/downloadablerecoveryimage
    2. Sign in with your Microsoft Account (this is the email address we asked you for at the start of the call)
    3. From the list of Surface devices available, select the device that you need a recovery image for
      Please note that while you will only be presented with devices that are currently registered on your account, you will also be presented with the option to get an image for a different type of device. If you try to use this option, you will be prompted to enter the serial number for that device
    4. Download the recovery image using the button on the page
    5. When the download bar pops up at the bottom of your screen, save the file in a location you will be able to find it.
    Format USB Drive:
    1. Insert your USB drive into the USB port of your PC.
    2. From the desktop, open File Explorer
    3. Tap and hold or right-click on the USB drive and choose Format
    4. Select FAT32 as the file system and enter a Volume label to name the USB drive, such as RECOVERY, and then tap or click Start
    5. Tap or click OK to erase the contents of the USB drive
    6. Tap or click OK when the format is complete
    Create a recovery drive:
    1. On your Surface or PC, open recovery image that you downloaded by double-clicking it
    2. At the top of the window tap on Extract and then Extract all. Select the USB drive you formatted earlier for the location and click Extract.
    Perform USB recovery image:
    1. Turn the Surface off by pressing the power button
    2. Insert the USB recovery drive into the USB port
    3. Press and hold the volume-down (-) rocker
    4. Press and release the power button
    5. When the Surface logo appears, release the volume-down (-) rocker
    6. When prompted, choose your language options and keyboard layout
    7. Select Troubleshoot
    8. Select Recover from a drive. If prompted for a recovery key, select Skip this drive at the bottom of the screen.
    9. If prompted, select Repartition the drives.
    After the completion, please double check if issue is still there or not. Feel free to respond on this thread to keep us updated.
