Battery drain after update
Split from this thread.
I have the same problem with my Surface pro 2017 battery life after some update on August 2019.
My battery life drop to just about 2 hours of using. I have check my device, there is no any strange activity app.
This is my battery report, and i notice that it take very short time than usual to charge my device, and of course, drop faster too.
I'd need to see the full battery report. Can you upload it to your OneDrive and share a link in a reply?
Yes
No
I've just reinstalled windows but does not solve the problem. This is full battery report. I'm gonna downgrade to version 1809 to see if it would help.
https://1drv.ms/u/s!AsGqFs-eTaqCgp5bxJLvOrILmBIcvA?e=tBco2Q
Yes
No
Hello I have the some problem after that update, until this point i use the surface with the same matter for about 4 or 5 Hours, now i only can get 2 or 3 hours
Surface – Firmware – 103.2614.257.0
Surface Embedded Controller Firmware – Firmware
  • 103.2614.257.0 improves battery performance.
Yes
No
A better test would be to use the Surface specific recovery image and completely
reimage from that. Your battery cycles are pretty high - how long have you had
(with a different Windows computer if yours is not working properly)
and download a recovery image for your Surface. You will need a 16GB USB stick
formatted FAT32 (use a Windows computer). Use FULL format and not quick format
and give the volume a name like surfboot.. Best to use a new previously unused
USB stick for this. There are full instructions and a video at
Yes
No
>Surface – Firmware – 103.2614.257.0 Surface Embedded Controller Firmware – Firmware 103.2614.257.0 improves battery performance.
When did you get this update? Which Surface Pro do you have?
Yes
No
Im backing up data to I will try your method tonight.
I reinstall Windows 10 1809 version yesterday but nothing change. The battery drop too fast and charge too fast. Its a firmware problem or battery problem? I bought this device in July 2017.
This is my charge time. It took less than an hour to charge from 25% to 100%.
Yes
No
Did you use the recovery image specifically for your Surface or not? If not,
please try it. The only other thing to try is to run your Surface on battery
until it shuts down on its own. Then plug it in and let it charge completely for
several hours before you use it. Do this three times. If this fails to fix the
issue, it is most likely a failing battery.
Yes
No
I've just recover to the oldest version 1703 and then turn off automatic update.
Now im gonna monitor the battery life following your method and will report after three times. Thanks you for your support.
Yes
No
I am having the same issue.
Surface Pro 2017 i7
From 100% to 5% in less than 3 hours (maybe around 2 hours)
This problem started recently so I think it's related to the update.
Yes
No
are you able to roll back the update? or is this the firmware update?
Yes
No
Last updated April 5, 2021 Views 3,087 Applies to:
