Will CCleaner interfer with MSE, SuperAntiSpyware free edition and Malwarebytes?
I have Windows 7
CCleaner was installed on my computer the has MSE already.  I'd like to install the spyware and malware above.  Will CCleaner cause problems?  Do I need to uninstall it?
It is better to use only one at a time. There is a possibility that conflicts may occur.
MCSA, MCSE,MCP,MCTS & Exchange.
Mark helpful posts & answers
I have Windows 7
Microsoft Security Essentials – Installation Checklist and Frequently Asked Questions
Windows Insider MVP 2016-2018
CCleaner has settings on the Cleaner - Applications tab to prevent it from removing
reports and so on from antivirus/antispyware/security programs.
Personally, using MSE, I don't run the resident function of either MalwareBytes or
SuperAntiSpyware. Remember when you run an On-Demand scanner to update
the definitions files prior to the scan for best results.
Use CCleaner - to stop the MalwareBytes Run Once at startup
MBAM - Tools - Startup - click to YES under Enable to switch to No.
The run MBAM as On-Demand.
Use the SAS Portable version and you don't have to disable the resident functions
of the regular version.
SAS - Portable version
http://www.superantispyware.com/portablescannerhome.html
For the installed version :
For setting up SuperAntiSpyware as an on-demand scanner if desired :
You have to check all the entries - the entries are by SuperAdBlocker which is used by
SuperAntiSpyware and SuperAntiSpyware.
Autoruns - Free - See what programs are configured to startup automatically when your system
boots and you login. Autoruns also shows you the full list of Registry and file locations where
applications can configure auto-start settings.
http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
Under this section in AutoRuns :
HKLM\System\CurrentControlSet\Services
SASDIFSV SASDIFSV.SYS SUPERAdBlocker.com and SUPERAntiSpyware.com c:\program files\superantispyware\sasdifsv.sys
SASENUM SASENUM.SYS  SUPERAdBlocker.com and SUPERAntiSpyware.com c:\program files\superantispyware\sasenum.sys
SASKUTIL SASKUTIL.SYS SUPERAdBlocker.com and SUPERAntiSpyware.com c:\program files\superantispyware\saskutil.sys
There may be others as my memory is not clear - there are 4 and probably 5 entries and they
will NOT be altogether so look close for both SuperAntiSpyware and SuperAdBlocker notations.
Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle <- Mark Twain said it right!
Rob Brown - past Microsoft MVP - Windows Insider MVP 2016 - 2021
Microsoft MVP Windows and Devices for IT 2009 - 2020
Last updated August 25, 2020 Views 750 Applies to:
