What is "System Progressive Protection 3.7.17?
My pc is infected by a virus called "system Progressive Protection 3.7.17. It will not allow me to run any virus or malware removal. What can I do?
Last updated May 16, 2018 Views 12,876 Applies to:
Windows Insider MVP 2016-2018
See the following: http://www.bleepingcomputer.com/virus-removal/remove-system-progressive-protection
Have you sought assistance from your antimalware provider (Avast, AVG, Avira, McAfee, Norton, Trend Micro, etc)?
Alternatively, try these “free” on demand scanners which will not interfere with your resident AV program - you might need to run them in Safe Mode or Safe Mode With Networking:
Go to www.malwarebytes.org and download, install, update and run the free version – just follow the prompts.  You may need to rename the installation file to 123.exe or something similar to prevent the malware from disabling/blocking the installation.  Or you might want to download the installation file to a flash drive or CD and then install Malwarebytes on the infected computer.
And/or
Try Hitman Pro Trial Version: http://www.surfright.nl/en/hitmanpro This program may be run from a flash drive.
And/or
Try TDSS Killer: http://www.bleepingcomputer.com/virus-removal/remove-tdss-tdl3-alureon-rootkit-using-tdsskiller TDSS Killer may be run from a flash drive.
And/or
Try the Eset Online Scanner: http://go.eset.com/us/online-scanner
And/or
Try this MS scanner: http://www.microsoft.com/security/scanner/en-us/default.aspx
And/or
You may need to use one or more of the following offline scanners - you'll need to burn a CD using a different computer and change the boot sequence on your computer to run the scan - instructions are included with the links:
http://windows.microsoft.com/en-US/windows/what-is-windows-defender-offline
http://www.bitdefender.com/support/How-to-create-a-BitDefender-Rescue-CD-627.html
http://www.freedrweb.com/livecd/
http://support.kaspersky.com/viruses/rescuedisk?level=2
Good luck...
http://voices.washingtonpost.com/securityfix/2009/09/what_to_do_when_rogue_anti-vir.html#more
http://ask-leo.com/i_run_antivirus_software_why_do_i_still_sometimes_get_infected.html
