how to remove "PC Health Kit"
I have tried to remove this Health Kit for some time and have noticed my computer is very slow and getting pop-ups.  I tried to uninstall but rec'd C:/Program does not exist so can be uninstalled.  What can I do to remove from programs.  Afraid it is a virus = hv seen some free removals online but not sure if they are safe.....any recommendations?
Last updated April 4, 2020 Views 10,528 Applies to:
Malwarebytes considers it to be a rogue program: http://forums.malwarebytes.org/index.php?showtopic=127755
I suggest you run the following free programs:
Go to www.malwarebytes.org and download, install, update and run the free version – just follow the prompts.
And/Or
Try Hitman Pro Trial Version: http://www.surfright.nl/en/hitmanpro   This program may be run from a flash drive if needed.
And/or
Try the Eset Online Scanner: http://go.eset.com/us/online-scanner
And/Or
http://www.bleepingcomputer.com/download/adwcleaner/
AdwCleaner is a program that searches for and deletes Adware, Toolbars, Potentially Unwanted Programs (PUP), and browser Hijackers from your computer.  By using AdwCleaner you can easily remove many of these types of programs for a better user experience on your computer and while browsing the web.
The types of programs that AdwCleaner targets are typically bundled with free programs that you download from the web.  In many cases when you download and install a program, the install will state that these programs will be installed along with the program you downloaded.  Unless you perform a Custom install, these unwanted programs will automatically be installed on your computer leaving you with extra browser toolbars, adware, and other unwanted programs.  AdwCleaner is designed to search for and remove these types of programs.
http://ask-leo.com/i_run_antivirus_software_why_do_i_still_sometimes_get_infected.html
Windows Insider MVP 2016-2018
^_^
Windows Insider MVP (Security)
