Windows Vista- Can't turn on Windows Defender
I TRIED TO TURN ON WINDOW DEFENDER. IT GAVE AN ERROR 0X800705B4.
WHAT DO I DO NOW?
[Original title: 0x800705b4  window defender error code]
Last updated April 11, 2019 Views 145,735 Applies to:
Hi tropicalvic,
Let’s follow these steps which should fix the issue.
Step 1
If you have any third party antivirus software and firewall disable them temporarily and make sure that the Windows Firewall is turned on. Then check if the issue reappears.
Step 2
1. Open Run, and  type in services.msc then press Enter.
2. In services window, locate Windows Defender service in the services list.
3. Verify that the Status is Started. If the Status column is blank,
right click on the service and select Start.
4 If you get error trying to force start the Windows Defender service, try to change the Startup Type to Automatic, and then restart the computer.
Hope the information helps. Please post back and let us know.
Regards
Debleena S
Microsoft Answers Support Engineer
Visit our Microsoft Answers Feedback Forum and let us know what you think.
52 people were helped by this reply
