My PC infected with conduit malware when update FlashPlayer
I inadvertently download the Conduit Malware when updating Adobe Flashplayer. This malware attached itself to the Bing search bar and was not detected by Windows Defender, Malwarebytes, nor CCleaner trial additions. I can no longer use IE nor Bing until this malware is removed. Any ideas on how to remove it short of a reinstall?
[Original Title: conduit malware]
Remove Conduit Search (Removal Instructions)
Remove Conduit Toolbar and search.conduit.com (Uninstall Guide)
How to reset Internet Explorer settings
Try Hitman Pro Trial Version: http://www.surfright.nl/en/hitmanpro This program may be run from a flash drive.
Try TDSS Killer: http://www.bleepingcomputer.com/virus-removal/remove-tdss-tdl3-alureon-rootkit-using-tdsskiller TDSS Killer may be run from a flash drive.
Try adwcleaner: http://www.bleepingcomputer.com/download/adwcleaner/
Try Malwarebytes Antimalware (free version, do not install the trial or Pro version) - http://www.malwarebytes.org/products/malwarebytes_free/
You can start here:  https://consumersecuritysupport.microsoft.com/  (which will lead to the paid support options of http://www.answerdesk.com if you are in the US)
In other regions not served by the link above, go here:   http://Support.microsoft.com/security and go to the “assisted support” or contact us menu.
This web site - http://www.bleepingcomputer.com -  contains details for many of the common infections, often immediately after they began to appear in the wild, and instructions are provided for how to remove the infections using their malware removal guides. They also have forums where you can seek help from people who specialize in malware removal.
This may also be helpful - How to get rid of malware:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-security/how-to-get-rid-of-malware/ba80504b-61f1-4d71-960f-b561798b7b42
-steve
^_^
Windows Insider MVP (Security)
Last updated August 21, 2020 Views 98,112 Applies to:
