Installation error 80070643
I get an install error of 80070643 when attempting to install...
Looking through the install log, I see this error
SI (s) (E0:1C) [19:17:10:808]: Note: 1: 1401 2: HKEY_LOCAL_MACHINE\Software\Classes\*\shellex\ContextMenuHandlers\MSSE 3: 5
MSI (s) (E0:1C) [19:17:10:808]: Product: Microsoft Security Essentials -- Error 1406. Could not write value  to key \Software\Classes\*\shellex\ContextMenuHandlers\MSSE.  System error .  Verify that you have sufficient access to that key, or contact your support personnel.
Does anyojne know what the permissions on the Key should be?
Last updated June 2, 2018 Views 36,944 Applies to:
At this point I would recommend trying the steps here
http://social.answers.microsoft.com/Forums/en-US/msestart/thread/908fad3e-f9fc-4d8a-be83-ae7d3bc48db5
 and if it is still not working submit a case to support
Bill
I updated the permissions on the keys to the same as the HKLM\Software\Classess\*  and did the steps above just in case and rebooted. Install worked just dandy after that.
