PC Power Speed popups on my system but i never downloaded that program
I recently started getting pop ups saying that PC Power Speed had detected errors on my computer.  But I never downloaded anything by that name and when I run Norton 360 it doesn't find anything.  PC Power Speed says that it's a certified Microsoft Partner.  Is this true?  Wheater it's true or not I would like to safely remove this program from my computer, but when I go to the start menu and choose All Program and click on uninstal PC Power Speed,  I get a window that looks like I'm about to install a program rather that get rid of one.  How do I safely get rid of this program?
Last updated May 16, 2018 Views 3,178 Applies to:
HI,
PC Power Speeds is a rogue program which tries to convince you to buy it to correct issues your
computer does not really have. Its a scam.
If you need to check for malware here are my recommendations - these will allow you to do
a thorough check and removal without ending up with a load of spyware programs running
resident which can cause as many issues as the malware and maybe harder to detect as
the cause.
No one program can be relied upon to detect and remove all malware. Added that often easy
to detect malware is often accompanied by a much harder to detect and remove payload. So
its better to be overly thorough now than to pay the high price later. Check with these to an
extreme overkill point and then run the cleanup only when you are very sure the system is clean.
These can be done in Safe Mode - repeatedly tap F8 as you boot however you should also run
them in regular Windows when you can.
TDSSKiller.exe. - Download to the Desktop - then go to it and Right Click on it - RUN AS ADMIN
it will show any infections in the report after running - if it will not run change the name from
tdsskiller.exe to tdsskiller.com. Whether it finds anything or not does not mean you should not
check with the other methods below.
http://support.kaspersky.com/viruses/solutions?qid=208280684
Download malwarebytes and scan with it, run MRT, and add Prevx to be sure it is gone.
(If Rootkits run UnHackMe)
Download - SAVE - go to where you put it - Right Click on it - RUN AS ADMIN
Malwarebytes - free
http://www.malwarebytes.org/products/malwarebytes_free
SuperAntiSpyware Portable Scanner - Free
http://www.superantispyware.com/portablescanner.html?tag=SAS_HOMEPAGE
Run the Microsoft Malicious Removal Tool
Start - type in Search box -> MRT  find at top of list - Right Click on it - RUN AS ADMIN.
You should be getting this tool and its updates via Windows Updates - if needed you can
download it here.
(Then run MRT as above.)
Microsoft Malicious Removal Tool - 32 bit
http://www.microsoft.com/downloads/details.aspx?FamilyID=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en
Microsoft Malicious Removal Tool - 64 bit
http://www.microsoft.com/downloads/details.aspx?FamilyId=585D2BDE-367F-495E-94E7-6349F4EFFC74&displaylang=en
also install Prevx to be sure it is all gone.
Prevx - Home - Free - small, fast, exceptional CLOUD protection, works with other
security programs. This is a scanner only, VERY EFFECTIVE, if it finds something come back
here or use Google to see how to remove.
http://www.prevx.com/   <-- information
http://info.prevx.com/downloadcsi.asp  <-- download
PCmag - Prevx - Editor's Choice
http://www.pcmag.com/article2/0,2817,2346862,00.asp
Try the trial version of Hitman Pro :
Hitman Pro is a second opinion scanner, designed to rescue your computer from malware
(viruses, trojans, rootkits, etc.) that have infected your computer despite all the security
measures you have taken (such as anti virus software, firewalls, etc.).
http://www.surfright.nl/en/hitmanpro
If needed here are some online free scanners to help
http://www.eset.com/onlinescan/
Original version is now replaced by the Microsoft Safety Scanner
http://onecare.live.com/site/en-us/default.htm
http://www.microsoft.com/security/scanner/en-us/default.aspx
http://www.kaspersky.com/virusscanner
Other Free online scans
http://www.google.com/search?hl=en&source=hp&q=antivirus+free+online+scan&aq=f&oq=&aqi=g1
After removing any malware :
Also do these to cleanup general corruption and repair/replace damaged/missing
system files.
Start - type this in Search Box ->  COMMAND   find at top and RIGHT CLICK  -  RUN AS ADMIN
Enter this at the prompt - sfc /scannow
How to Repair Windows 7 System Files with System File Checker
http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program
generates in Windows Vista cbs.log
http://support.microsoft.com/kb/928228
Also run CheckDisk so we can rule out corruption as much as possible.
How to Run Disk Check in Windows 7
http://www.sevenforums.com/tutorials/433-disk-check.html
If any Rootkits are found use this thread and other suggestions. (Run UnHackMe)
http://social.answers.microsoft.com/Forums/en-US/InternetExplorer/thread/a8f665f0-c793-441a-a5b9-54b7e1e7a5a4/
If needed AFTER you are sure the machine is clean of all malware. (DO NOT USE IF
MALWARE IS STILL PRESENT.)
How to Do a Repair Install to Fix Windows 7
http://www.sevenforums.com/tutorials/3413-repair-install.html
For extreme cases :
Norton Power Eraser - Eliminates deeply embedded and difficult to remove crimeware
that traditional virus scanning doesn't always detect. Because the Norton Power Eraser
uses aggressive methods to detect these threats, there is a risk that it can select some
legitimate programs for removal. You should use this tool very carefully, and only after
you have exhausted other options.
http://us.norton.com/support/DIY/index.jsp
If you are in North America, you can call 866-727-2338 for help with virus and spyware infections.
See
http://www.microsoft.com/protect/support/default.mspx for details. For international information,
see your local subsidiary Support site.
Hope this helps.
Rob Brown - Microsoft MVP - Windows and Devices for IT 2010 - current
Windows Insider MVP 2016 - current
