HELP ME PLEASE, I found trojan horse and backdoor
I did a scan with  microsoft Essentails. Its was a long long scan. When the scan was done it found a trojan horse and say it qas dangerous so i deleted it and turn off me computer and turn on. Then i did the scan again to be sure its gone. The same scanner (microsoft essentails) it found another thing the name was backdoor:win32/ircbo.gen!z and again i deleted it. But im not thinking its gone because me computer is doing some strange ****... Im not really good in computers so if one of u guys can help me it would be really really nice.
Last updated May 16, 2018 Views 140 Applies to:
How long have you been using Microsoft Security Essentials?
See Can I Install MSE To Clean Up My Already Infected Computer?
If you think your computer may still be infected try the following free independent scanners which will not conflict with your installed AV program:
Go to http://www.malwarebytes.org/products/malwarebytes_free/ and download, install, update and run the free version – just follow the prompts.
And/or
Try the Kaspersky Virus Removal Tool: http://www.kaspersky.com/antivirus-removal-tool?form=1 If necessary you can download the program to another computer, put the removal tool on a flash drive and then run the removal tool on the infected computer.
And/or
Try Hitman Pro Trial Version: http://www.surfright.nl/en/hitmanpro   This program may be run from a flash drive if necessary.  Hitman Pro is available as a 30 day trial version.
And/or
Try the Eset Online Scanner: http://go.eset.com/us/online-scanner
And/or
Try TDSS Killer: http://support.kaspersky.com/viruses/disinfection/5350#block3 TDSS Killer may be run from a flash drive if necessary.
And/Or
Try this MS scanner: http://www.microsoft.com/security/scanner/en-us/default.aspx
And/Or
You may wish to try System Restore (that may or may not eliminate your issue and remember to be sure you’ve backed up any documents, pictures, music, etc you wish to save before trying it).  Alternatively - - - you can reformat/reinstall the operating system, restore to factory settings if that’s an option with your computer,  take your computer to a repair tech or seek assistance from MS Answerdesk (that will cost you however):
http://answerdesk.microsoftstore.com/msusa/en-us/answerdesk
Good luck…
http://ask-leo.com/i_run_antivirus_software_why_do_i_still_sometimes_get_infected.html
Windows Insider MVP 2016-2018
Welcome to the Community Fernidalnvm:
Please look up at MSE's History tab and tell us the name of MSE's first detection; and if it was removed or quarantined?
In addition to running the scanners suggested by Le Boule above (I'd personally recommend: HitmanPro and ESET), you might need to perform some additional remediation procedures for Backdoor:Win32/IRCbot.gen!Z, to return your infected computer to its pre-infected state, as this threat may make lasting changes to a computer's configuration that are NOT restored by detecting and removing it.
Would ask you to please post back with your results. Wish you Good Luck and a Happy New Year (same to you Le Boule ;)).
Lenovo ThinkCentre A55-8705/Windows XP Home Edition SP3/.NET3.5SP1/IE8/MSEv4.4.
