April 9, 2024
Click here to learn more 💡
May 10, 2024
Word Forum Top Contributors:
WINWORD.EXE remains running when Word is closed - high CPU usage
Try starting Word using the Safe switch (hold the Ctrl key whilst starting Word) accept the popup prompt
Create a doc as usual, save and exit. Does the process end? (As seen in task manager>Processes)
If yes then some add-in is causing the problem.
Currently win11 Pro & O365 Bus, multiple devices
121 people found this reply helpful
·Was this reply helpful?
I have the exact same issue. Fan is running. Only thing open is Explorer. Also running Windows 7 and Office 2010. CPU 50% with winword.exe.
Tried the safe open option and no difference.
Will reboot and see if that helps.
I'd be grateful for advice as well
Thanks you,
Cathy
The bit version of win and the bit version is of no consequence (other than you would need 64bit win to install 64bit Office, & MS doesn't recommend that you use 64bit Office)
If it operates fine when Word/Safe is run but is intermittent when using Word normally it means something is holding the word process open. Usually an add-in, which maybe Anti-virus integrated software, and if its the anti-virus program its often necessary to uninstall/completely remove the AV before retesting
Ensure also that you are not running Word in compatibility mode.
There were also problems reported by at least two Anti-Virus software makers, so perhaps uninstall any AV, and use that makers completely remove utility, before retesting
b) Windows Explorer shows preview - WINWORD.EXE starts
Has anyone else came to the same conclusion?
Disabling preview does not work for me. WINWORD.exe always stays resident after existing word and consume 5 times as much CPU as when it was actually being used.
UD: It turned out to be an add-on. In my case a maths one. Cannot remember which.
Simple solution, worked better than any other idea. thanks a ton
Last updated May 7, 2024 Views 76,021 Applies to:
