Remembering different view settings for different documents
I work with different documents that have different page layouts, font sizes etc, such that each is optimally viewed in a certain layout (e.g. web/print) and at a certain zoom level. In Word 2010, each document rememebered its last view, but in Word 2013 it seems that applying a certain layout&zoom level to one doc makes all other docs be displayed with the same setting, which is very inconvenient.
Is there a way to make these view settings rememebred document-wise?
Thanks!
If you didn't have VBA installed, none of it would work.
Open the template in Word - File > Open. You can't edit the code unless the template is opened, and not merely installed as an add-in.
Press ALT+F11 to open the VBA editor. Locate the project
Graham Mayor (Microsoft Word MVP 2002-2019)
For more Word tips and downloads visit my web site
https://www.gmayor.com/Word_pages.htm
Last updated September 16, 2021 Views 953 Applies to:
