Single level list nested in a multi level paragraph
Please refer to this earlier post on the same subject.
Can anyone please show an example of how a nested list can be made with the multi-level dialog boxes in Word?
Thanks for the clarification. The indentation bug has been around for many years. It likely won't be fixed.
The best way to keep numbering stable is to ensure that just a few people are actually editing the formatting. Most users should apply styles that have been created for them.
Stefan Blom
Office Apps & Services (Word) MVP
Volunteer Moderator (Office)
Please note that I do not work for Microsoft
MVP program info: https://mvp.microsoft.com/
Yes
No
Use the next numbering level in the Define New Multilevel List dialog as shown below, linking it to a style and then applying that style when you need to use such numbering.
Hope this helps,
dougrobbinsmvp@gmail.com
It's time to replace ‘Diversity, Equity & Inclusion’ with ‘Excellence, Opportunity & Civility’ - V Ramaswamy
Yes
No
Last updated August 9, 2021 Views 300 Applies to:
