Drag and drop does not work
I'm unable to drag and drop in Word 2007 with Windows 7, 64 bit. Is there a fix for this?
Last updated July 17, 2018 Views 27,726 Applies to:
If you have a dialog box open (such as symbols, cross-reference, ...), drag-and-drop does not work, although you can still edit in your document. Close the window and it works again.
Sometimes it's just handy to keep these windows open in a second screen (eg. when adding a large number of symbols or tables, figures).
21 people were helped by this reply
If you are not able to drag and drop text follow these steps
1.      Open the Microsoft Word document.
2.       Click the 'Microsoft office' button.
3.       Click the 'Word Options' button. (The 'Word Options' dialog box appears) .
4.       In the left pane, click 'Advanced'. (The 'Advanced' screen appears).
5.      In the 'Editing options' section, select the 'Allow text to be dragged and dropped' check box.
6.      Click 'OK'.
If you are trying to drag and drop images follow these steps
1.      Insert the picture from the insert menu.
2.      Right click on the picture.
3.      Select text wrapping and change it from inline to any other option (like through, in front of etc).
4.      Now try moving the picture using your mouse.
Let me know if this helps.
Vinay G, Microsoft Answers Support Engineer.
• We appreciate your participation in MS Forums, Help us understand your needs better. To share your valuable Feedback please Click here.
