Why are my onedrive documents opening in read-only mode after installing office 365 home edition?
- Subscribe
- Subscribe to RSS feed
Do you find the issue with a specific Word document or with all Word documents?
How are you accessing these files, is it from within the Office applications or directly from One-Drive?
If you are syncing files from within Office 2013 applications, then you may remove and re-add the One-Drive account and then verify the results.
If issue still persists, you may provide us a screenshot of the issue and help you better.
I hope the above information helps. Let us know if you need further help.
·Was this reply helpful?
I'm having this problem too. I'm opening the files from the onedrive section of file explorer. It stopped happening for awhile but now, since the 8.1 update its occurring again. It's very annoying because if forces me to save a new version of the file every time I work on the damn thing.
Whenever I open a file from OneDrive folder it opens as read-only. I have repeatedly tried to change the properties to OneDrive but it reverts all folders and files back to read-only. I can no longer save to the OneDrive folder. WTF?
25 people found this reply helpful
dougrobbinsmvp@gmail.com
Screen shots by Snagit from www.techsmith.com
260 people found this reply helpful
Download the file to the local drive and open it from there.
This is not a solution. Why is this occurring and how can it be fixed?
YES! this is driving me crazy. I'm working on a project and need to create a new file over and over again. When I try to change the settings, it immediately reverts back to Read-Only. Why can't we get a clear answer on this? Raju, I appreciate your attempt to help but you responded by asking us questions.
1) It is all Word Documents.
2) I am accessing them through One Drive.
2a) You did not follow this question with instructions. Am I to imply from your question that I/we should first be opening up Word and then opening up our files through the program instead of clicking directly on our files?
2b) If so, that is pretty clunky
3) This direction seems to imply that some of us have a One Drive with a bug? If so, will you be sending out updates in the near future?
4) Well, that is a round-about dismissal of our concerns.
All my Word and Excel files are opening in read-only too. It didn't use to be like this except for the past week it seems. I have to open and then Save As in another folder. When I copy the files back to OneDrive I need to have Administrator authorization. Something happened. I've been "Googling" (yeah, not "Binging") for the past week looking for an answer. Microsoft, this must be a big issue, can we please get a solution?
53 people found this reply helpful
Last updated February 27, 2021 Views 91,395 Applies to:
