March 10, 2025
Access Top Contributors:
MS Project Calendar view truncates text in tasks
·Was this reply helpful?
David,
I'm guessing the issue is long task names in relatively short duration tasks? Using Bar styles and "wrap text" I was able to get below:
That being said - there are limitations about what can be done in the Calendar view. Tell us more about your situation (perhaps a screen shot?), what version and what patch level you are using and we'll try to be more helpful.
Hi - thanks for your response. I'm still having issues with the calendar view. I went into bar styles, set to wrap text, but the task names are still being truncated in print view and on the printed hard copy.
Image 1 - Setup of Calendar view before printing
Image 2 Calendar in print view with task name truncated.
Last updated September 26, 2024 Views 2,101 Applies to:
