I have PowerPoint 2016 (Office 365 ProPlus version 1705 build 8201.2213) installed but I do not seem to have PowerPoint Designer.
The Designer pane dosn't pop up automatically when I insert images (I am not using a presentation with a default theme and I am using the Title Slide layout.
If I go to File->Options->General, I also do not see the Designer or Intelligent Services options.
I suspect that the issue may be a setting on our Group Policy but that's just a suspicion and if that is the case, I can't work out which setting is the problem.
Could anyone shed any light on what is required to enable PowerPoint Designer?
Thanks
Julie
