Outlook 365 Problems With Build 16251
A number of problems are happening with Outlook 365 after loading Build 16251.  Cannot send emails, cannot delete emails.  Outlook does not seem to be communicating to the email server as each time Outlook is opened the same emails are received.  Receiving several error msgs such as 'Disk is full or not working' (Significant room on disk), or 'Insufficient resources available'.  This is on Surface Pro 2, using the POP3 standard with Comcast as the email server.  In addition, when the Surface is shut down and then started Outlook opens on its own. The other apps in Office seem to be working properly.
Have uninstalled and installed Office with same problems occurring.
Have also posted on Feedback Hub
***Post moved by the moderator to the appropriate forum category.***
We appreciate that you have already sent in your feedback regarding the issue and this would be carefully reviewed.
We'll gather additional details and information about your concern that will help determine the cause and address it. The feedback items regularly receive Microsoft responses to see what we're doing about your submission. Revisit frequently for status updates.
For more information on Feedback Hub, see our support article and YouTube video
. In order to submit a new feedback, please follow the steps below:
1. Type Feedback Hub in the Cortana search and press Enter.
2. Navigate to Feedback in the left menu, click + Add new feedback tab.
3. Select the Problem, and share the details you want to us to know, and choose the appropriate category and subcategory.
Note: Reproduce your concern if possible while is monitoring is enabled. To do this, click Begin monitoring or Start Capture to start recording and Stop monitoring when you’re done.
4. Once you've completed the form and monitoring, click Submit.
5. Click My feedback at the top, then find the item you submitted.
6. Open the item you submitted, then click Share.
7. Click Copy link, then paste the link here in your response (It will look like https://aka.ms/<unique link>).
If you have further queries, don't hesitate to post back.
Regards.
Problem seems to have been resolved via an Office update.
Last updated May 22, 2018 Views 79 Applies to:
