Outlook 2010 Contacts/activities problem
Outlook 2010 no longers lists older emails under the contacts/activities option and new emails do not show up either.  I tried a scanpst and it did not help.  Is there an option I need to configure or do an index to get the emails to show up under activities?
Jeff
Last updated November 3, 2018 Views 5,744 Applies to:
No, it is not coming back. In fact, Activities was removed from Outlook 2013. Journal is still there but that is about it.
http://www.slipstick.com/outlook/journal/making-the-journal-work-in-outlook-2013/
Diane Poremsky [Outlook MVP]
Outlook Resources: https://www.slipstick.com
https://www.outlook-tips.net
** I don't work for Microsoft, I just volunteer here.**
The difficulty started when I imported (no dups) a pst file to the existing file.  Didn't go away after I went back to the original file or with any other working file that was ok before.
I did a 2010 reinstall and the problem is gone- all files including the merged files are ok.  The only things that didn't get restored were the rules I had set up, I'm guessing something within 2010 got corrupted during the original import process.  I did try a 2010 repair first before the reinstall- no help.  Only other problem with the reinstall was my raid boot devise was disabled after the remove so I had to enable it.  The good news is all seems ok now
Thanks Diane and Russ for responding.
Jeff
