Question
icloud add in will not load
beech35p asked on
Spent 4 hours on the phone with Apple but could not figure out why the Icloud add in will not load in Outlook 2010. De-installed and re-installed all Apple products, Outlook and Office 2007. No change. The add in is visible and disabled. Check the box to install and recycle only to find it back in the disabled section.
59 people had this question
Abuse history
The answered status icon Answer
Did you already configure the icloud? Go to Control panel and start icloud from there. It will set it up Outlook and enable the addin. If its not setup, you can't start the icloud app. If you hd it configured but removed it from outlook, you need to enable it through the control panel, not outlook Outlook and icloud problems
Diane Poremsky [Outlook MVP]
Outlook Resources: http://www.slipstick.com
http://www.outlook-tips.net
1 person found this helpful
Abuse history
Girish M replied on
Run ‘Outlook 2010’ as an administrator and then try to enable the icloud addin.
To open ‘Outlook’ as an administrator:
Browse to the location C:\Program Files\Microsoft Office\Office14 or C:\Program Files(x86)\Microsoft Office\Office14, right click on the ‘Outlook.exe’ file and click on ‘Run as Administrator’.
You may also install the icloud application in compatible mode and check if it helps. For more information refer to the following thread:
http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/cdd894f8-1ee2-43e5-952b-d04c25779a7f/
6 people found this helpful
Abuse history
beech35p replied on
Thank You! No luck though. The add in still remains disabled even after opening in "Administrator" mode. Any other ideas???
Thanks again.
2 people found this helpful
Abuse history
Girish M replied on
Mention the steps you tried to enable the Add-in?
Refer to the steps in the following link to turn on installed Add-ins:
http://office.microsoft.com/en-us/outlook-help/enable-or-disable-add-ins-in-office-programs-HA010034127.aspx#BM17
Also refer to the following link and check if it helps:
http://msdn.microsoft.com/en-us/library/ms268871.aspx
You may check if Outlook is running in compatibility mode.
Navigate to C: \Program Files \Microsoft Office \Office14 \Outlook.exe, right click on Outlook.exe -> Properties ->Compatibility ->Uncheck “Run this program in compatibility mode for” and “Run this program as an administrator”, click Apply and OK and then check.
Be the first person to mark this helpful
Abuse history
Abuse history
sysmarks replied on
were you able to resolve your issue with outlook and icloud? I have the same problem and have been following all the advice posted but to no avail.
Abuse history
TomW2580 replied on
I am looking to resolve this same issue...  I too have followed all advice previously posted, yet no resolution as of yet...
Abuse history
Girish M replied on
Hi Tom,
You may remove and re-add the account from the iCloud Control Panel and Outlook and check.
Note: Ensure the account is also removed in Outlook if present. You may also check if the version of iCloud Control Panel installed on the computer is compatible with Outlook 2010.
If issue persists, you may reinstall the iCloud application and verify the results.
Thank you
Abuse history
12Tom replied on
I too have had this trouble since the end of august. I only just realised the it was the add in not being enabled.
 I did set up another user account on my computer as a test added I cloud to outlook the add in worked fine. It was exactly as it should be.
But try as I may I cant get it to work in my regular user account........
any advice?
I am using outlook 2010 with windows 7
Abuse history
12Tom replied on
any advice?
I just found the answer http://czerwinb.blogspot.ca/2012/12/re-enable-icloud-2x-outlook-add-in.html
when I was in the add ins section under manage in the drop down window I selected disabled items and chose the icloud plug in, restated out look and we are back in business....
thanks to the link above
7 people found this helpful
Abuse history
courtneycleaver replied on
I found the add-in under the Disables add-ins, and I selected it, and clicked "Enable". Nothing happened. Now the icloud add-in isn't showing up anywhere. How do I re-install the add in?
Abuse history
