On a Windows 7 Enterprise, 64-bit PC I want to install Sharepoint Designer to work with an Office 365 (Plan P1) Sharepoint site that's just been upgraded by Microsoft. I'm not very clear which version of Sharepoint that means I'm using but I suspect it's 2013.
My PC runs 32-bit Office 2010.
So, should I install Sharepoint designer 2010 because it's compatible with my Office 2010, or Sharepoint Designer 2013 because it's needed to work with my upgraded Office 365 Sharepoint?
And should I use the 32-bit version of Sharepoint Designer to maintain compatibilkity with my 32-bit Office, or should I use 64-bit Sharepoint Designer because I need no compatibility with Office and the 64-bit version would be more compatible with my 64-bit Windows?
Thanks for any guidance you might have.
Kevin
