Alert setting in OneDrive
I need to set alert on document and folders in OneDrive, but I cannot get the ribbon in the OneDrive UI, where alert command could show up. Please guide for a resolutions.
hi lalitmohan3205,
i'd like to confirm if you refer to onedrive for business.
if yes and you see the onedrive ui like below:
please click return to classic onedrive at the left-bottom corner,
then you will get the ribbon in onedrive ui like below and according to the following article to set up alerts:
create an alert for a folder, file, or list items
if you have clicked return to classic onedrive at the left-bottom corner and still cannot see the ribbon, please click gear->show ribbon.
if no, please provide some screenshots about the issue with us for further investigation. to upload screenshots, you can click use rich formatting at the bottom and then click the icon of insert media.
if you refer to onedrive, i suggest you post a thread in our onedrive forum for further assistance.
regards,
gene
Last updated February 10, 2020 Views 459 Applies to:
