Powershell Connect-EXOPSSession and ISE debugger
I am using the MFA module to do multi-factor auth, per https://technet.microsoft.com/en-us/library/mt775114(v=exchg.160).aspx
The problem is, once this module is installed on my win10 desktop, I can't see how to load the module in any way except via the shortcut, which opens a generic powershell window with no debug or intellisense options.  This makes debugging scripts very challenging.
How can I load this into the ISE?
Am I going about this sideways?
Thanks
Last updated November 7, 2019 Views 1,608 Applies to:
Hi CheezeWhizze2,
Based on my research, it is not feasible to load this module in ISE. You will need to use the generic PowerShell you have installed to connect to Exchange Online using MFA. I understand that if you can use it in ISE, it will be more convenient for debugging. Given the situation, I suggest you submit feedback via the link below:
https://office365.uservoice.com/forums/273493-office-365-admin
Thanks for your understanding.
Yang
