April 9, 2024
Click here to learn more 💡
May 10, 2024
Install, Redeem, Activate Forum Top Contributors:
Office Home and Student 2013 products not working on Windows 10
Unfortunately that seems to be a "feature" of Windows 10. It likes to break valid Office installations... <sarcasm>.
Without a specific error code we can't provide specific suggestions.
Here are a number of potential fixes for install "hangs". Ignore that they are for different versions of Office.
http://office.microsoft.com/en-us/help/office-known-issues-HA102919019.aspx?CTT=5&origin=HA102901439
In an enterprise scenario where the administrator has configured the installation source to be a protected network share instead of the Internet, the computer’s system account might not have access. When the installation’s source is not available because of permissions, the installation fails and appears to hang with the progress stuck at 10%.
Workaround Please see Office 365 or Office 2013 installation process stops at the “10% - Configuring” stage.
Microsoft Office 2013 or Office 365 hangs during setup
http://support.microsoft.com/kb/2445957
http://support.microsoft.com/kb/929135 1 - Cleanboot install tip - This is a Click To Run (CTR) specific error
http://quicksolver.blogspot.in/2012/02/office-2010-installation-stalls-or.html
Disable Print spooler from starting:
- Start > run > services.msc > look for Print spooler > Right Click on print spooler > Properties > Stop the print spooler services > Change the Start up type to Disable.
- Restart the computer
- and then try installing office
I solved the problem myself by reloading the OS on the affected drive as several “trojans” had been put in my Windows 7 which, I think, caused the problem. Both the all-in-one printer and Windows 365 were affected suddenly after a threatening screen came up “screaming” at me to phone a specific number to dispose of my “bugs” by MS “experts” which, no doubt, had been put in deliberately by these extortionists in the hope they would be able to charge me a great deal for fixing the problem they had caused. It was time consuming but probably a good idea to reload the OS at times as I built the machine myself with two HDDs and it refreshes it although needing a great many updates to catch up to where it was originally.
Rather than the "shotgun' approach you could try finding the specific error code. The way to do this is use "verbose logging". It captures all messages: success messages, informational warnings and severe errors. Looking through the captured logs can help you identify the specific error causing your problem.
http://support.microsoft.com/kb/2545723 - fix Its to turn logging on and off
http://blogs.technet.com/b/odsupport/archive/2010/12/30/trouble shooting-office-installation-failures.aspx Office 2003-2010, analyse log
http://support.microsoft.com/kb/826511 - help interpreting logs
http://support.microsoft.com/kb/906485 - Enable logging on XP
http://technet.microsoft.com/en-us/library/cc978342.aspx
http://support.microsoft.com/kb/223300 - Fix it enable XP, Server 2003-8
http://support.microsoft.com/kb/2826852
http://technet.microsoft.com/en-us/library/bb742606 Control Event Logging
“Verbose logging” is a setting that exposes more information during the installation process. It will capture “warning” as well as “error” messages that provide us with clues to your problem.
You can post the generated Logs in Onedrive and give a link to them to your technician if you need technical help.
I found a pattern in one verbose log file set that I have not yet had a chance to confirm in others, but you can give it a try. The pattern is each log file is for a separate component. If you open the files from the start and jump to the bottom of each file you will see that they report successful install of a component. There should be an odd number of log files, find the one in the very middle. It is also probably the largest. It is most likely to be the one reporting the error that caused the install to end and back out. All of the log files after that point will be reporting the uninstall of previously installed components in reverse order.
Here is an example of the error message:
<snip>
MSI (s) (48:2C) [18:15:25:059]: Product: Microsoft Office Single Image 2010 -- Installation operation failed.
MSI (s) (48:2C) [18:15:25:059]: Windows Installer installed the product. Product Name: Microsoft Office Single Image 2010. Product Version: 14.0.4763.1000. Product Language: 0. Manufacturer: Microsoft Corporation. Installation success or error status: 1603.
</snip>
Do a google search for “error status: 1603”
If you don’t recognize an error, upload the entire log file set to Onedrive.
The thing is, the “useful” part will be very small and very specific and you probably won’t recognize it. So posting extract may catch the problem, but often miss the important info, so it is best to give us access to everything captured.
PS: remember to turn Verbose Logging OFF after you fix the problem. It will continue to generate “excess” logging files during all installations, including Windows updates.
To do onetime verbose logging:
Diagnosing When Setup Stops Responding
At times, Office Setup stops responding (hangs), and you do not receive any error message. The best thing to do in this situation is to restart your computer, and run Office Setup again with complete verbose logging turned on (with one additional option). To
do this, start Office Setup. To do so, follow these steps:
- 1. Click Start, and then click Run.
- 2. In the Open box, type the following command-line, and then click OK:
path\Setup.exe /L*v! C:\Verboselog.txt
Note that Path is the full path of your Office source location.
To enable Windows Installer logging yourself, open the registry with Regedit.exe and create the following path and keys:
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Installer
Reg_SZ: Logging
Value: voicewarmupx
The letters in the value field can be in any order. Each letter turns on a different logging mode. Each letter’s actual function is as follows for MSI version 1.1:
v - Verbose output
o - Out-of-disk-space messages
I - Status messages
c - Initial UI parameters
e - All error messages
w - Non-fatal warnings
a - Start up of actions
r - Action-specific records
m - Out-of-memory or fatal exit information
u - User requests
p - Terminal properties
+ - Append to existing file
! - Flush each line to the log
x - Extra debugging information. The “x” flag is available only on Windows Server 2003 and later operating systems, and on the MSI redistributable version 3.0, and on later versions of the MSI redistributable.
”*” - Wildcard, log all information except for the v and the x option. To include the v and the x option, specify “/l*vx”.
Note This should be used only for troubleshooting purposes and should not be left on because it will have adverse effects on system performance and disk space. Each time you use the Add/Remove Programs tool in Control Panel, a new Msi*.log file is created.
When looking through the MSI logs we will typically want to look for a value 3 entry in the logs. Windows installer returns codes during the install which will indicate if a particular function was successful or not.
Value 1 = Success
Value 2 = Cancel
Value 3 = Error
Note: make sure to turn off verbose logging after you are done.
Enable verbose logging before collecting the log files.
- 1. Click on Start -> All Programs
- 2. Accessories -> RUN
- 3. Type reg add HKLM\SOFTWARE\Microsoft\ClickToRun\OverRide /v LogLevel /t REG_DWORD /d 3
- 4. Click on OK.
Now try to install Microsoft Office 2013 to get the error message so that the log files get created.
Provide the complete error log present in the ‘Temp’ folder to help you better.
Follow the steps below to access the ‘Temp’ folder.
- 3. Type %temp% -> Click on OK
Following are the log files that may be present in the %windir%\temp folder (c2r is for Click to Run):Bootstrapper*.log
- 1. c2r_*.log
- 2. C2Rintegrator*.log
- 3. Firefly*.log
- 4. Integratedoffice.exe_c2r*.log
- 5. Interceptor*.log
- 6. *.exe.log
- 7. *_c2rdll*
MSI, “Normal”, installations the log files will look like MSI****.LOG
As computer scientists we are trained to communicate with the dumbest things in the world – computers –
so you’d think we’d be able to communicate quite well with people.
Prof. Doug Fisher
Thank you! Disabled the print spooler and virus software, rebooted the pc and the install finished! Thank you for the advice!
Last updated January 21, 2024 Views 1,038 Applies to:
