Office 2010 "change product key" does not work.
I have Office 2010 installed on a 2003 Server, and when I try to activate the product (change product key-which I have 5 licenses for), the change button (link) that takes you to the activation wizard, does nothing.
When I click on "change product key," nothing happens.
I have done this 90 times over the past two months on a Windows 7 deployment, and changing the product key always allowed me to input my valid 25-digit licence key.
Any suggentions, other then removing it and re-installing?
Last updated February 20, 2019 Views 29,923 Applies to:
Q: What is your current office version which you have in your computer and what version of office are you trying to install now.
 Can try these step before giving answer:
There is one more step which you can try :
 1) Open your word document or other applications like Excel, PowerPoint, etc.
2) Choose "File" > "Help" in the menu.
3) Then click "Change Product Key" in the right list.
4) Then a dialog box apears and enter your product key in the blank. And click "Continue" like this.
5) There are two options in another new dialog box. Choose "Install Now".
6) A process window pops up. Wait for a few minutes.
7) Then you can see it is finished and click "Close" to exit.
Jateen Kumar Mahapatra Microsoft Engee.
