8002801d automation error - library not registered
Hi Guys,
I hope you can help me on this one.
On my work laptop I am running Windows 7 64 bit, Office 2003.
I mistakenly installed the Office 2013 preview (I wanted to just download it) and then as it had installed on my work laptop, I uninstalled it.
Since doing that, I now cannot open Excel through VBA, I am getting an Automation Error: 8008201d - Library Not Registered when I run the following command:
Set objExcel = CreateObject("Excel.Application")
I have searched online about this extensively, and found one solution to the problem to re-register the .dll files.
This is where I am having a problem however, I have tried re-registering several files, but the some will not register, I get another error saying it has loaded but failed to call on DllRegisterServer with Error Code 0x80004005. I am an administrator and have tried running cmd with administrator rights, to no avail.
I then also updated to a copy of Office 2007 that I had, but having the exact same issue.
Please help me in any way you can, it is crucial that I get this working and I would be grateful to anyone who can assist.
Kind regards,
Sam Cackett
Last updated March 21, 2019 Views 25,916 Applies to:
You may try the following:
Step 1. Go to Run Prompt and Type “regedit” and click ok Step 2. Expand HKEY_LOCAL_MACHINE Step 3. Expand Classes Step 4. Expand TypLib Step 5. Expand 00020813-0000-0000-C000-000000000046 Step 6. Select 1.8 Step 7. Right Click on 1.8 and Delete this.
166 people were helped by this reply
thank you!!! after searching the web for hours ... this solved my problem, too!!
Great decision. It helped me too!
Solved my issues as well. Thank you very much!
Many thanks josmongeorge - this did the trick for me.
Many Thanks josmongeorge, for the answer ........
for me i faced the same error while switching from Access 2007 to Access 2010 .....
I checked the same path in Regedit and instead of 1.8 i found 1.7 and by deleting it my issue is resolved.....
hope that would be helpful for some as well...
DanS
Hi ,
  As per above instruction I have deleted "00020813-0000-0000-C000-000000000046" from registry. But still it is not working. It gives me the same Run Time Error.
Please help to solve the issue.
BR
Saikat
I was getting that exact error message and this solution helped fix my issue!
Thanks
Years later... Still helpful!  Thank you. Solved my problem, too.  :)
Dan
It works!! Thank you so much! :)
