how to generate all possible combinations of numbers using microsoft excel (ideallywithout macros)
I have got two groups of numbers.Group A: 1, 2, 3, 4, 5, 6, 7, 8; Group B: 9, 10, 11, 12, 13, 14, 15, 16. I would like to select 2 numbers and 4 numbers from group A and group B respectively, and there is no repetition in every possible combination of numbers. I was wondering whether I could have microsoft excel generate all possible combinations of numbers. Thanks a lot.
Tim
Last updated August 16, 2019 Views 59,639 Applies to:
You may refer to my solution at the following link - http://www.ashishmathur.com/create-all-possible-combinations-from-different-ranges-without-using-vba/
For any follow up questions, please post in the Comments section of the link shared above.
Hope this helps.
Ashish Mathur
http://twitter.com/excelashish
23 people were helped by this reply
Thanks, Ashish. I have got data set 1 (1 to 8) and data set 2 (9-16). I would like to generate all possible combination of 6 numbers: in every possible combination, 2 numbers are from data set 1, and 4 numbers are from data set 2 and no repetition. If I apply the combination formulas (not permuatation), the number of all possible combinations will be [8!/(6!*2!)]*[8!/(4!*4!)=1960. I would like to have excel list all these possible 1960 combinations. In the file available in the following link, I list a few possible combinations in rows 13 to 19 for illustration purposes. Thanks.
Tim
Hope this helps.
I have used this with great success for 2 columns of data, but when I have tried to used the same solution and applied it to 3 columns of data it doesn't work. Is there a similar solution I can use to gain a list of all unique combinations from 3 datasets?
What problem are you facing?
Ashish Mathur
This is very much helpful, I have used this with 6 data sets and gave me wonderful results.
Thanks Ashish.
You are welcome.  If my reply helped, please mark it as Answer.
Ashish Mathur
