Unexpected error - power query - specified method is not supported
On one of our office machines we get a - specified method is not supported - error when we are trying to load data from a query.
It concerns office 2016. We are able to  execute the same query on other machines so we don't understand why it fails on this one machine.
When we execute the query the preview window is populated ok, when we "load and save" excel will retrieve a few rows and then the error will pop-up, (we then see in gray the table which is filled with a few rows and the last row is incomplete, not all data is loaded)
here is the error message:
Error Message:
Specified method is not supported.
Stack Trace:
Microsoft.Mashup.Evaluator.Interface.ErrorException: Specified method is not supported. ---> Microsoft.Mashup.Evaluator.Interface.ErrorException: Specified method is not supported. ---> System.NotSupportedException: Specified method is not supported.
   at Microsoft.OleDb.Column.GetColumnType(Type type)
   at Microsoft.OleDb.Serialization.PageWriter.WriteSchema(DataTable schemaTable)
   at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.<>c__DisplayClass13.<OnBeginGetDataReaderSource>b__12(EvaluationResult2`1 result)
   at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.OnBeginGetResult[T](IMessageChannel channel, BeginGetResultMessage message, Action`1 handler)
   --- End of inner exception stack trace ---
   at Microsoft.Mashup.Evaluator.RemoteDocumentEvaluator.Service.OnBeginGetDataReaderSource(IMessageChannel channel, BeginGetDataReaderSourceMessage message)
   at Microsoft.Mashup.Evaluator.MessageHandlers.TryDispatch(IMessageChannel channel, Message message)
   at Microsoft.Mashup.Evaluator.ChannelMessenger.ChannelMessageHandlers.TryDispatch(IMessageChannel channel, Message message)
   at Microsoft.Mashup.Evaluator.MessageHandlers.Dispatch(IMessageChannel channel, Message message)
   at Microsoft.Mashup.Evaluator.ChannelMessenger.OnMessageWithUnknownChannel(IMessageChannel baseChannel, MessageWithUnknownChannel messageWithUnknownChannel)
   at Microsoft.Mashup.Evaluator.EvaluationHost.Run()
   at Microsoft.Mashup.Container.EvaluationContainerMain.Run(Object args)
   at Microsoft.Mashup.Evaluator.SafeThread2.<>c__DisplayClass15.<CreateAction>b__14(Object o)
   at Microsoft.Mashup.Container.EvaluationContainerMain.SafeRun(String[] args)
   at Microsoft.Mashup.Container.EvaluationContainerMain.Main(String[] args)
   at Microsoft.Mashup.OleDbProvider.DataHost.MashupResource.GetStatus()
   at Microsoft.Mashup.Client.Excel.DownloadWorker.<RetrieveResultPagesWorker>b__1()
   at Microsoft.Mashup.Client.Excel.DownloadWorker.InvokeWorker(Func`1 action)
Invocation Stack Trace:
   at Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
   at Microsoft.Mashup.Client.ClientShared.UnexpectedExceptionHandler.HandleException(Exception e)
   at Microsoft.Mashup.Client.Excel.FillManager.FillSession.HandleDownloaderException(IWorkbook workbook, Exception e)
   at Microsoft.Mashup.Client.Excel.FillManager.InitialFillSession.ResumeFill(Boolean onTimer)
   at Microsoft.Mashup.Client.Excel.FillManager.UpdateQueries()
   at Microsoft.Mashup.Client.Excel.FillManager.<OnFillUpdateTimerTick>b__0()
   at Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Hello Koen,
We suggest that you repair your Office by following the instructions on this link.
Last updated February 6, 2021 Views 1,121 Applies to:
