PowerPivot for Excel 2010 32-bit installation issues.
I have a problem installing PowerPivot for Excel onto my system.
I am running Windows 7 64-bit, Office 2010 32-Bit, and SQL Server 2008 R2 64-Bit.  I have installed all shared Office components.
Every time I try to install PowerPivot 32-bit, I get the following error:  "Setup is missing prerequisites: This add-in requires Excel 2010. If you have 32-bit Excel, you must install the 32-bit version of the add-in. If not, you must install the 64-bit version. Go to http://go.microsoft.com/fwlink/?LinkId=168472".  I think there maybe a conflict with 64-bit SQL and 32-bit Office?  Any ideas?
Last updated August 7, 2019 Views 3,325 Applies to:
Click on the link below and check if it helps:
http://support.microsoft.com/kb/982765
