Excel =Max not working??
Why does my =Max formula E: =MAX(M2:N2) only keep showing the N2 number regardless if it is higher or lower than M2?
It sounds like the M2 value is numeric-text...not a number.
Try this in a blank cell:
=ISNUMBER(M2)
If the result is FALSE
...check the contents of M2 for leading/trailing spaces
...Check if M2 has a number format of "Text"
Let us know what you find
Ron Coderre
Former Microsoft MVP - Excel
Last updated May 27, 2021 Views 15,094 Applies to:
