Auto fit Row Height is not sufficient
The Auto fit Row Height is not sufficient, to me the borders are tightly fitting, I find this annoying and spend unnecessary time trying to increase the height size, so that I get a neat empty margin / border round the text / content in each cell .
How do I (hopefully a default setting) format Excel to keep Auto Fit Row Height at (Auto Fit Row Height + 15), or is there someway I could have some Macro to ensure this view in my Workbooks and Worksheets?
Thanks
Last updated January 3, 2020 Views 5,480 Applies to:
There is no built-in setting for this. You could run the following macro instead of selecting Format | AutoFit Row Height:
Sub AutoFitPlus()
  Dim rng As Range
  Selection.EntireRow.AutoFit
  For Each rng In Selection.Rows
    rng.RowHeight = rng.RowHeight + 15
  Next rng
End Sub
This will only look nice if vertical alignment is Top or Center instead of the default Bottom. You could add that to the macro:
Sub AutoFitPlus()
  Dim rng As Range
  Next rng
  Selection.VerticalAlignment = xlCenter
End Sub
Kind regards, HansV
www.eileenslounge.com
