We use an Access 97 database for our applications as a master database, so we can easily destribute this to customers. We access this master database using Adox to get the tables and columns (fields), compare it to the live SQL database and make changes where necessary.
Since the patch, we are getting errors when requesting the columns for wider tables. We are using an Adox.table and then use the .columns. When doing this for tables with more than 128 fields (exact number not sure) give error 3251 "Object or provider is not capable of performing requested operation".
This is causing all kinds of problems.
Anyone know of a work around, or what is causing the problem now?
