Word VBA for drop down field - enter first letter to see a selection that begins with that letter
Hello ,
I have a Drop Down form field with a list of cities.
Is it possible with VBA code to automate the drop down field so that when a user Tabs into the field, if they type the first letter of the city they desire, the list will display the city that begins with that letter?  (Then ideally, with the desired city chosen, the user can Tab out of the field to select the displayed city.)
Thank you
Mark
Or, as macros are permissible in your document, you could create a userform to hold the names of the cities in a list box and display that listbox on entry to the field. List boxes can be configured to select by letter (or the full value).
Assuming a legacy form field create a simple userform in the document e.g.
The code behind the form would be as simple as
Option Explicit
Private Sub CommandButton1_Click()
ActiveDocument.FormFields("Text2").Result = Me.ListBox1.Text
Unload Me
End Sub
Private Sub UserForm_Initialize()
    Me.Caption = "Select City"
    With Me.ListBox1
        .TabIndex = 0
        .AddItem "Albany"
        .AddItem "Birmingham"
        .AddItem "Colchester"
        .AddItem "Doncaster"
        .ListIndex = -1
    End With
End Sub
Include your list of cities in place of those shown and you would call it from a macro, in an ordinary module in the document, run on entry to the form field. I have left the default names, for the elements and have assumed a text form field named 'Text2' You can change the names as appropriate.
Option Explicit
Sub GetCity()
UserForm1.Show
End Sub
When you tab into the field the userform displays and you can make your selection. You are also not limited to the 25 selections in a dropdown form field.
Graham Mayor (Microsoft Word MVP 2002-2019)
For more Word tips and downloads visit my web site
https://www.gmayor.com/Word_pages.htm
Last updated October 5, 2021 Views 1,173 Applies to:
