I use Word 2016. For previous versions, using the Replace function would alter Page up/down navigation. In Word 2016, I no longer see the tiny icon in the bottom right corner that would restore PageUp/Down back to normal. What do I do now? My PageUp/Down
is stuck in the mode of looking for my Replace search term.
This has been overlooked in recent versions of Word, unfortunately. You can restart Word to get the "default" functionality back for Ctrl+PageUp (and Ctrl+PageDown).
Alternatively, if you usually need to move between pages, you can assign keyboard shortcuts to the PageUp and PageDown built-in commands in the Customize Keyboard dialog box (File | Options | Customize Ribbon | Customize).
Stefan Blom Word MVP Volunteer Moderator ~~~~ Note that MVPs do not work for Microsoft MVP program info: https://mvp.microsoft.com/ MS Community FAQ: https://answers.microsoft.com/en-us/page/faq ~~~~
