We found a problem with some content in '...xlsx'. Do you want us to try to recover as much as we can? If you trust the source of this workbook, click yes.
I have 2016 Office Pro Plus.
Windows 10 Pro 64bit running on intel i7 16GB.
Only Newly created Files.
I think the problem with Recent Updates send with Office which I can not find in list of add remove.
All file with Data connection to 2012 SQL server are getting this message.
I have saved data connection to file.
I have uninstall office competently, Restart and reinstall.
I have removed all Data connection files from c:\..\Documents\*
I have tried different station to open file with same results.
Still I get same result ?????????????????
Is there a way to fix this?
Found this is bug with Excel 2016 Pro on my Computer.
Looks like I am not the only one having problem.
While linking data "Import Data" make sure to uncheck checkbox "Add this data to the Data Model
Follow link below.
https://answers.microsoft.com/en-us/msoffice/forum/all/issue-with-csv-import-in-excel-2013-connection/74e47d1c-b227-4e8f-b4fe-958c14a2abaf
Reply In reply to deleted message
Thanks Stacy.
I found problem and Work around it.
I have update Part of Question.
Good to know that you have fixed the issue.
Stacy
Last updated November 29, 2023 Views 10,859 Applies to:
